This is usually caused by 2 things
IF your mower had a primer bulb that bulb has a hole in it or there is debris in the bottom of the fuel float bowl that has blocked the main fuen jet. The remedy is to remove the float bowl and clean out the bowl, bowl nut and the main fuel jet in the threaded area of the bowl nut with CARBURETOR CLEANER. If your mower has a primer bulb the bulb will most likely need replaced. Since you did not include a make and model number this is a horribly generic and somewhat unprofessional response. You left me little option but to respond as best I could at this time. If you respond with a make and model number I can provide the steps you should take to perform a DIY repair.
Thanks for choosing FixYa,
Kelly
