Question about Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS
Counterweith shaft broke off
OOOPPS.
My scope fell and the counter weight shaft broke off. There is a plate that could be screwed on but I cannot get the replacement part from Meade.
Mine is a 2080 GEM circa 1985 model.
Where perchance could I replace that plate. Would appoxy glue do the trick otherwise? The counterweight is HEAVY.
  • gammamcc Sep 02, 2008
    That's "counterweight.."
Bring the broken parts to a local proffessional machine shop. It will no doubt cost a bit, but they should be able to do it. No, epoxy won't work.
Posted on Oct 09, 2008
Cement counterweight broken
difficult to do much there. you could try gluing something to the bowl, but it is very unlikely to hold for many cycles. you can buy new outer bowl / frames from the manufacturer.
Nov 19, 2013 | Whirlpool Calypso GVW9959K Top Load Washer
How do you take off the motor from the pump assembly
Turn the circuit breaker off to the pump. Undo the band that holds the motor and flex plate to the pump. Unscrew the 5 screws on the diffuser ( front of pump ) That will expose the impeller. Remove the rear cover of the motor, (2 -1/4" screw heads) Pull off the rear cover. The impeller might have a screw in the center of it. If it does, the screw is left handed thread. Turn the screw clockwise to remove. Use a 7/16" open end wrench to hold the shaft at the rear of the motor. Put the wrench behind the plate with the two springs on the shaft. You might have to turn the shaft a little to get the wrench on. Remove to screw and remove the impeller, (counter clockwise). Unscrew the 4 motor flange bolts and pull the flex plate from the motor.
Apr 10, 2011 | AO Smith SQ1202 Pool Pump Motor
Ir tourch has brocken off the unit
That's OK. When IR broke off did it leave any hole into the cavity of the scope? If it did, use some black anodized aluminum (or black plastic) plate 1/16 or smaller and mold it and fit to where it broke off only if there are holes.
Once the plate been fitted tightly. Now you drill some holes. The number of drill holes is up to you. Go down to your local fastener business, the carry all kinds of screws, machine screw, bolts, nuts, everything that you might need. Get the machine screws that are the self threading. They will look like a little machine screw with SAE threads but it will be tapered on end with a small notch cut in the end. This way you will not have to use a tap to thread the holes.-----One more thing here, pre-tap the drill with self tapping machine screws. This way you can clean out the scope cavity Then apply a thing layer of black rubber cement to the cover plate and then screw the machine screws. The length of the machine screw are critical. You don't want the to long where the reach far into the scope cavity. It could disrupted the flow of light to the NV scope.
Now, for a IR lumination. Get head light with one high luminating bulb. Get an IR lens and have it fitted to the head light, now you have IR lumination. Simple, hey. stewbison
Feb 06, 2011 | Yukon (744105200223) Weapon Sight
The 2 concrete blocks on the front of the drum have come off. what's the easiest way to get to them to put them back on?
Are you referring to the two counter weights that are suppose to screw onto the front section of the drum behind the front concealment panel?
If so, these weights don't just fall off. If they just fell off, this means the mounting has failed. They are quite simple to install. They generally are screwed into place. Click here to view an exploded diagram of the unit. The counter weights are labeled as 321 and 322 on the provided diagram. Are those the "concrete blocks" you are referring to?
Jul 23, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Instructions to replace door lock assembly
Hello,(1)Open the door and remove the two screws in the door lock latch plate on the edge of the door by backing them out with a Phillips screwdriver in a counter clockwise direction.
(2)Remove the two screws (located on the interior lock face plate)holding both halves of the lock assembly to the door by backing them out with a Phillips screwdriver in a counter clockwise direction,pull each side of the lock assembly from the door,using a flat blade screwdriver to pry them off if needed. (3)Pry the latch bolt out of the door by inserting the edge of a flat blade screwdriver under the latch plate on the edge of the door.slide the latch assembly out and set aside.(4)Insert the new latch assembly into the hole left by the old latch bolt.Trim the recessed opening with a sharp chisel if the new lock latch plate is larger than the old latch plate.Secure the latch to the door with the two screws provided by turning them in a clockwise direction with a Phillips screwdriver.(5)Hold both side of the new lock assembly to the holes in the faceof the door.Line up the shaft from the lock cylinder into the slotted hole in the latch assembly.Make sure the lock face plate with the screw holes is facing the inside.Attach the lock assembly to the door by turning in the screws with a Phillips screwdriver in clockwise direction.(6)Remove the old striker plate from the door jamb by backing out the two screws with a Phillips screwdriver in a counter clockwise direction.Install the striker plate that came with lock kit with the screws provided using a Phillips screwdriver in clockwise direction.
(7)Close the door and test the operation of the lock from the inside and outside using the turn lever and the key.Make adjustment to the striker plate if needed by removing the holding screws.Reposition the striker plate and replace the screws
Thanks
May 26, 2010 | Ovens
Radian pro Gt head broke that holds the scope.
You can still order the plate that attaches the camera/scope to the head from Eagle Optics directly at this link:
http://www.eagleoptics.com/tripod-accessories/vortex/radian-pro-gt-quick-release-plate
Feb 10, 2010 | Radians Radian Pro-GT Tripod
Replaceing the wet end seal on my hot tub
disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
2000 Suzuki ATV Pully assembly problem
HELLO; Go on line and you can get a manual off of e-bay or google. The weights your talking about are the counter weights for one half of the drive belt sheive. GOOD LUCK.....GREASY
Aug 07, 2009 | Sport & Outdoor - Others
Whirlpool Duet GHW9400PWO: Replacement of the rear counter weight
This is a simple repair. All that should be required is to remove the back panel to access the counterweight. I've performed this repair on several occasions. Loosen the bolts that sandwich the weight between the mounting plates and the whole weight should slide out of its mounted position on the back of the tub. Insert the new weight by sliding it in place and then re-installing the mounting plates and bolts. Tighten until snug. Do NOT overtighten as you may crack the weight. I hope this helps you.
Sep 16, 2008 | Whirlpool GHW9400 Duet Washer
Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS Logo
81 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
