When I connect the Hotdive 2.5 Sata ext inclosure with WD 250 Gb HDD, the R/W LED is a constant red. The drive icon is not recognized in either COMPUTER or DEVICE MANAGER.
  • 3 more comments
  • staubrj561 Sep 03, 2008
    GINKO: Shutting both computer and ext enclosure down for 10 minutes didn't work.
    ESKE: tried 2nd drive, same results.
    Both primary HDD and enclosure is SATA, wasn't aware a jumper was used
    Tried all four usb ports (Dell Vostro 510 Laptop) same results
    Changed cable - Same results
    disk management doesn't recognize the ext drive
  • 2,794 Answers
Make sure your drive isn't connected to a USB hub.
Make sure you have an external power supply hooked up to it.
If that doesn't work, turn the power off for 20 seconds and restart it.
If you have access to the control panel go to administrative tools select computer management, select disk management and see if the partition exists for your drive as well.
Posted on Sep 03, 2008
    Brigadier General:
  • 6,966 Answers
If I may offer an alternative procedure:
  • physically remove the WD 250 Gb SATA HDD from the Hotdive 2.5 SATA ext enclosure, connect it directly to a free SATA port of a desktop PC;
  • borrow a spare SATA HDD and try it on the Hotdive 2.5 SATA ext enclosure. You could even try your laptop's own HDD (if SATA).
Both procedures would determine which is at fault, the enclosure or the 250HDD.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
    Master:
  • 638 Answers
Technician at your place is much advisable because all the experts advice should definately help u but nothing is going your way.as the technician at your place will be having all the require parts to be checked available with him and can replace and check what is wrong with the system.
thanks.
if helped please rate the solution.
  • 2,071 Answers
A: There are two methods that I have seen work for this issue:
Method #1:
  1. Go to Start
  2. In the Search field, type in: device manager
  3. Open device manager and navigate to your USB controller
  4. Right click the drive and select Properties
  5. Be sure that the option for "Write Caching" is enabled
Method #2:
  1. Navigate to Device Manager using the above instructions
  2. Right click and Delete all of your USB controllers
  3. Reboot Vista
Vista will recognize that you have deleted the USB controllers and add the new hardware back to your system. This may fix anything that had been corrupt.
Hope this may help;
  • 928 Answers
Connect your drive to your computer then after that go to control panel then administrative tools then computer management. Go to the disk management see if your drive is recognized there. If it is and no drive letter is assigned. Assign on. Sometimes Windows does not automatically assign drive letters to specific drives hence does not come up as an icon
  • 66 Answers
Try other usb cable...or put ur hardisk into other inclusure
  • 6,487 Answers
Try connecting the external enclosure on adifferent usb port the best on is the USB port behind your computer tower so it supply much higher power..
Hope that helps.........
  • Mark Gil
    Mark Gil Sep 03, 2008
    Did you try a different usb cable to connect the enclosure to the computer because sometimes this is a problem with the usb cable....if you already did tried it the the problem here can be the enclosure itself...
  • Mark Gil
    This can be now a problem with the enclosure that you have better try a different enclosure so we can check if it will work.//
    Master:
  • 521 Answers
Have you done the proper jumper settings on your main HDD
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 02, 2008
  • 13,433 Answers
Hey,
Can you try another harddrive in the case, you may have a faulty case there, assumeing your harddrive is fine.
-Ekse
  • Ekse Sep 03, 2008
    seems you have a faulty inclosure replace it if you can. warranty?
  • Ekse Sep 03, 2008
    Also try another computer and plug it directly to the computer without any hubs.
  • 19,396 Answers
Try unplugging the computer from power, and the drive usb cable for ten minutes, this solve some problem on usb devices.
  • Ginko
    Ginko Sep 02, 2008
    If the reset did not work try using an usb powered hub in the middle, this sometimes fix the problem.
    If the HDD still does not work after the above then it is probably faulty.
    Here you can buy an USB hub: Linksys ProConnect USB2HUB4 4 Port Wired USB Hub
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
The 250g wd hard drive icon disappeared from the mac desktop and list of devices, without being disconnected. It is still vibrating, 1 of the 4 lights remains on,I had the geek squad at Best Buy plug it in...
If they plugged it into a WinPC, the PC won't be able to read the drive.
More then likely the SATA-to-USB card in the drive has gone bad (like mine did.)
I ended up buying a rocketfish 2.5" SATA HD enclosure kit from BestBuy... now my drive works fine.
Good Luck!
Oct 18, 2009 | Western Digital WD Passport 250GB Portable...
SOYO KT600 Dragon Plus mobo not recognize WD Caviar SATA 1TB HDD
Yuck! Soyo filed for bankruptcy in May and their website is gone!
You need to enable the SATA in the rom bios AND install the drivers for it; but, I hope you have the manual and the CD.
Jul 05, 2009 | Soyo Computers & Internet
I have asrock 845 mother board this board is not support my ext. hard drive .so plz give me solution.
1. If your system running Windows in SATA HDD, this will not support SATA External HDD
2. Better you try low capacity HDD such as 80GB, this will support and work with your system
thanks
ehsan
Jun 15, 2009 | Buffalo Technology 250GB USB SATA 2.0 HD...
HDD not Seen in system. WD 160 gb sata, WD 1600 AA BB
First things first .....check for power cable and data cable and make sure they are not tampered or damaged now move to next step>>>
kindly remove all jumpers in HDD now go to
Control panel>Administrative tool>Computer management>Disk management
you can see the disk here and change settings accordingly like assigning path and drive letter if this does not work
then just see that is it recognized in device manager as unrecognized device then update driver for HDD even now if the problem persists
KIndly consult the manufacturer
Thanks And Regards
May 12, 2009 | Western Digital Caviar SE WD1600AAJS 160...
250Gb hard drive for Acer travelmate 2300
No. I have tried a 250 Gb but my 2303 wont carry it. it will only recognize up to 130Gb but I did not try it with a 120Gb internally, my 250Gb IDE -HDD will run as an external but there is a power surge warning that comes up when I connect it, however I can run a 500 Gb SATA HDD with out this happening. MURRAY the MAGNIFICENT
Apr 08, 2009 | Acer TravelMate 2300 Notebook
Hot Drive - 2 Responses, neither worked
Hey, it seems you have a faulty inclosure.
Sep 03, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
