Question about Dell Axim X5 Pocket PC
Axim wont automatically shut off
I have the 400 mhz Axim. I have it set to shut off after 5 minutes of inactivity. If activesync is running and my Axim is in the cradle will it shut off after 5 minutes?
    Master:
  • 852 Answers
ActiveSync has a setting to synchronize periodically while connected. If the time between syncs is less than you timeout to shutdown, then the Axim may never shutdown. Try disabling the periodic sync and see if your Axim will turn off.
Posted on Sep 14, 2005
    Master:
  • 852 Answers
I would guess your light should dim after 5 minutes. But I bet your axim wont shut off for 2,3, or 4 hours. My battery is wonderful so I have it shutting off after 2 hours.
How do you install downloaded programs on the Dell Axim X30?
Downloaded programs can be installed onto the Dell Axim X30 using Microsoft ActiveSync. Microsoft ActiveSync can be installed onto your computer using the Dell Companion CD which came with your Axim X30.
Once Microsoft ActiveSync is set up on your computer, if the program you downloaded came in an installer file, then double-clicking on the file will start the installation wizard and the software will be automatically transferred to the Axim.
If the program you downloaded did not come as an installer file, then double-clicking it will bring up an error message. In that case, use ActiveSync Explore to copy the program file to the Program Files folder on your Axim.
Mar 05, 2011 | Dell Axim X30 Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
I can not connect my pocket PC
you connect by blue tooth wifi or cable ? check there setting too zonealarm block network access check its setting
Apr 20, 2009 | Computers & Internet
Lost CD Rom for my Axim x30. Anywhere I can download it?
You need ActiveSync from Microsoft. Unless you're using Vista which uses Windows Mobile Device Center. Connecting to the Axim to a Vista machine should automatically download the Windows Mobile Device Center software.
ActiveSync for XP and older systems can be downloaded here:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
You'll proabbly still want to update your Axim's firmware and drivers if possible.
Feb 04, 2009 | Dell Axim X30 Pocket PC
Dell axim x3i problem
Press and hold the reset on the back and press and hold the power button. This will reset to manufacturing settings.
Sep 21, 2007 | Dell Axim X3i (400 MHz) Pocket PC
Dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
Jun 14, 2007 | Dell Axim X30 Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
Cannot connect my Axim to my desktop.
I have tried to initiate the partnership using Activesync with my new Axim on three different laptops, three different versions of windows operating systems including 2K. I've spent hours on the hold for support and have been very disappointed with the level of training on this product. Obviously, we are not the only customers have problems with the usb connection but if you call the help desk, they act like it's a surprise to them. I have downloaded the usb patch and that does not correct the problem. I've been told by the support staff that I will have to upgrade to XP. Well that's just great. I need to spend $99 to upgrade my laptop to use a $200 pda. There are posting from XP users having the same problem so I'm not inclined to run right out to Best Buy! If I don't get a resolution fast, my Axim is being returned to Dell.
Axim after a hard reset!
Well to make a long story short, after the hard reset I lost all data, and I put the axim in the cradle and it sync-ed but I had to create a new name for it, and it never brough the software that I had originally installed on the unit back... is that common and everytime we'll do a hard reset on it, will we have to re-install all the software and assing a new name to the unit, if so than it is ridiculous!!!
Sep 14, 2005 | Dell Axim X3 Pocket PC
Why does my axim power on by itself?
I've noticed that mine will power itself on as well. But is usually goes like this... 1. Sync with computer 2. Unplug cable 3. Turn off Axim 4. ~1min later...Axim is on and at the password screen
Dell Axim X5 Pocket PC Logo
109 people viewed this question
Clive
Clive
Alun Cox
