Question about Dell E152FP 15" Flat Panel LCD Monitor
Dell Monitor Failing
I have a flat screen Dell monitor -- model E151FPb -- that is failing. the screen goes white and then if I turn it off and wait a bit, it will be ok when I turn it on again.
  • catherine_cr Sep 03, 2008
    Please explain what an EST is and how I get it replaced. Thanks!
    Thanks for your help. I will call a technician to replace this part.
    Sergeant:
  • 241 Answers
HI I have a DELL too
ON the Monitor hold down the menu button it sounds like it may be set on a different signal
Posted on Sep 03, 2008
  • Jayson Brollini
    Jayson Brollini Sep 03, 2008
    If you still do not have a picture go on the LCD menu and there will be a FACTORY RESET BUTTON
    Also unplug the monitor cable and plug it back in...Make sure the power is turned off. You can also unplug the AC plug from the wall and wait a minute ot two and plug it back in
    Rate the Advise from FixYa ExpertKindofcheap
  • Jayson Brollini
    catherine_cr
    Can YOU see my comments please let me know
    Master:
  • 521 Answers
Its the problem in the EST of the monitor.just get it replced to solve the problem.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 02, 2008
  • tech expert12 Sep 03, 2008
    the EST is a part located internally on the back of the monitor.some times it is because of the moisture collected on the EST.you can easily remove the EST but replacing it with new is bit hard.
    i will suggest you to call a tech to replace.it will cost u nearly
    20$ for the new EST with warranty.
    thanks.
    regards.
    fixya expert team
My dell E151fpb 15' monitor screen turns white
Look for loose connection between the LCD panel T-CON board and the logic board first, it may also have lost the 5vdc for the T-CON board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Aug 05, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
My DELL E151FPb LCD Monitor turns to white screen.
unplug the monitor on at the back fo the computer but leave the power plugged in and if you can see red,green ,blue bars jumpign around the screen it means that the monitor is good check the video card, but if you cant see the colored bars you need to get it repalce.this is monitor selft test process
Apr 15, 2010 | Dell Computers & Internet
Dog chewed cord in half. Not power cord - feed cord. I have it apart, where can I get a new cord. Its a Dell flat screen monitor- Model :E151FPb
You need a DB15 Video cable, they are available at say... Radio Shack, or the like, any good PC store should have them.
Feb 21, 2010 | Gateway FPD2275W LCD Monitor
My computer monitor will not stay on.
The problem may with the Ram inside your computer
Jul 07, 2009 | Dell E153FP 15" LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor Blackout
Here is a website that provides instructions to repair the inverter on a similar model:
http://josepino.com/?howto-repair-dell
Feb 23, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
DELL LCD monitor E151FPb turn white
If the screen is all white light then you can have a number of problems.
One could be a bad video board, the next could be a simple loose wire from the video board to the back of the lcd screen OR a simple blown fuse on the back of the actual lcd screen can cause the same thing.
Snaps are all sround these things and can be really stubborn at times. Best to start the bottom first then work up each side to the top.
Something flat, thin and with a decent sharp edge on it will help. A pocket knife held parallel to the joint between the front and rear plastic works, you can also sharpen the edge of an old credit card with a file (nail file works) This isn't as strong as a blade , but safer if you slip !!
Fran
Oct 10, 2008 | Gateway FPD1975W 19" LCD Monitor
Wacko Dell E151FPB
that sounds like a computer problem, not a monitor problem.  Plug the 'old' monitor in and see if your computer will boot with it.
Oct 14, 2007 | Dell E173FP 17" LCD Monitor
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
167 people viewed this question
Alun Cox
