Question about Cuisinart DLC-8S Pro Custom Food Processor
Lid won't lock
I've had my Cuisinart Deluxe 11 about two years. At first I had no problems, but now I can't get the lid to lock ... no matter what I do. It's driving me crazy....Help!!
  • ccwriter14 Sep 02, 2008
    solved my own problem...whew...thanks anyway
I've lost my instruction manuel for my Cuisinart Custom 11 ( DLC-8S) food processor and was hoping
you have one on file I can copy. Thank You in advance
Mickey Riley
Posted on Oct 11, 2008
Why Cuisinart mixer will not start?
All Cuisnarts have an interlock rod built in to the bowl assembly.
Make sure the bowl is positioned on the motor base correctly, and the actuator in the lid that pushes the interlock rod down is not bromen or damaged. If it is intact and working correctly, then check the switch it pushes on, or the main power switch.
May 20, 2014 | Cuisinart DFP-11 Deluxe Food Processor
How does the slide lock on the Cuisinard Custom 11 Food Process go back on?
The main important thing if you have an older style machine is to make sure when putting it together that the feed tube from the top aligns with the part of the bowl with the spring, so the button on the base gets depressed correctly. For some, the spring mechanism is on the front with the handle, for some it is opposite the handle... check the base for the tiny button to double check.
If you put the top on backwards it won't work (at least not correctly) -- but what's worse is that you are likely to break the locking mechanism when trying to get it apart... either on the lid, or the bowl, or both. It can be an expensive mistake.
Luckily, bowls and lids are available from Cuisinart... and many times the same bowl/lid was used for different machine numbers (the various models are about the base, not the bowls/lids/blades/etc.)
Dec 15, 2013 | Cuisinart DLC-8S Pro Custom Food Processor
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Can't get cuisenart pro 11 to start
I am assuming you have a DLC-8S Pro Custom 11, and not another Cuisinart food processor.
Remove the work bowl and all other parts completely from base.
Plug the base in, and turn it on.
Use a pen to press in the dark grey or black button on top of the base.
If you hear a spinning or other noise, the motor is still good.
Now that you have verified that the motor is good:
Put each work bowl piece on one at a time - if you don't out it on one at a time, it will not lock in properly.
Put work bowl on with work bowl handle facing front, make sure bowl locks.
Put lid on with hollow feed tube facing the back of the food processor.
Put pusher sleeve into lid's feed tube, with sliding lock switch facing the front of the food processor.
You should now be good to go.
Apr 07, 2009 | Cuisinart DLC-2011 PowerPrep Plus Food...
Machine on but not working
The video is generic, and may actually show a different model with completely different assembly instructions. For the DLC-8S and DFP-11 series, you want work bowl handle facing the front of the processor, feed tube on lid facing back of the processor, and sliding lock switch facing the front of the machine. For the DLC-2011, you want work bowl handle facing front, lid lined up with work bowl handle, and metal element hanging from pusher facing front.
To make sure the motor is working first, remove the work bowl, blade, etc. completely from the base of the food processor. Plug the base in and turn the food processor on. Then use a pen to press in the dark gray or black button on top of the processor - if it makes a sound, your motor is good. If it doesn't, call Cuisinart and get your processor repaired.
-Tha Mp3 Doctor
Mar 31, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
None of the buttons work on my Power Prep Pulse 11-CUP
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart prep 11 Plus won't run.
Remove the work bowl completely and separate the work bowl, lid and pusher sleeve. Plug the base into the wall outlet and press the on switch. Use a pen to depress the dark grey or black button on top of the base of the processor. If you don't hear a sound, then call Cuisinart and get it repaired. If you do hear a sound:
1. Put the work bowl on first, making sure the handle is facing front
2. Put the lid on, making sure the hollow feed tube is facing the back of the food processor
3. Put the pusher sleeve in, making sure the sliding lock switch faces toward the front of the processor
Turn the machine on - it should now be working
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart DLC-2 Mini Prep Plus Food...
Won't turn on
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
The manual is available on Cuisinart's website
Nov 27, 2008 | Cuisinart DFP-11 Deluxe Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Cuisinart DLC-8S Pro Custom Food Processor Logo
966 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
