Question about Samsung HLN617W 61" Rear Projection HDTV
Black Bar Sir, I recently replaced the color wheel in my Samsung TV and now I have a black bar or band across the bottom of my screen. This cuts off the top of the viewing screen and I am unable to see some of my football scores. This is serious stuff !!!!! Thanks for any advise, Ken
I know this is an old thread, but hopefully this will help someone! The problem is the DMD board is knocked out of alignment. It is adjusted by removing the small cooling fan and loosening the three gold screws that hold the assembly in place (two on the left and one in the middle of the board) AND by loosening the three (or four) spring loaded screws in the middle of the heat sink. Display a test pattern (from the service menu), tape the interlock switch closed (so you can power the set with the back off) and then carefully move the assembly (down is up; left is right.) An assistant helps! Once the image is correct, snug the screws up (they don't need to be torqued down!)
It took me FOREVER to figure this out - hopefully this will help someone else a little faster!
Todd
Posted on Mar 24, 2011
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
2" wide bar in center of Panasonic plasma TH-C42FD18 TV
The C5 board is bad. It is replaceable. Warning. always disconnect power cables from power board to y main on left and x main on the rt before ever messing with fat cables on boards across the bottom . The are created if power power is not isolated will vaporize these flat cable destroying the plasm panel. thes boars across the bottom are the c boards. If one of the connectors is loose it will create an vertical black bar in proximity to that connector. If the connector is not loose then replace that board. Also panel could be bad if c board does not fix. But remember to never connect or dissconnect these flat without disconnecting the power board from the sustain boards.
May 31, 2013 | Televison & Video
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
After changing color wheel on my samsung hlr 5067w tv my picture is high with black bar on bottom.top of heads are cut off.what went wrong? no proble before.
Hi,If you are experimenting vertical lines ,black bars ,color
distortion,pixilation,or white dots on the screen you might be having an
issue with the Dmd chip.This is how the DMD chip works:
http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip
is composed of around 2 million pixels that create the image on the
screen.You will need to replace in order to fix your problem.Have a
blessed one!
Feb 09, 2010 | Samsung HLR5064W DLP Projection TV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
SAMSUNG TV
Possible bad color wheel..need lamp code # to get correct
wheel part #.........................................T.
Nov 15, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Wide black bar on bottom of screen
I you know how to repair electronics its not a hard fix. The worst case would be the vertical output IC but im thinking th its nothing more then a capacitor in the verticle sweep circuit The average cost to repair this should be around 75 to 125 bucks. Good Luck
Jun 01, 2006 | Toshiba 32A60 32" TV
Samsung HLN617W 61" Rear Projection HDTV Logo
142 people viewed this question
Henry  Thomas
Henry Thomas
