Question about Kenmore 23012 Top Load Washer
Leaks How do you take the front and side panel off?
    Genius:
  • 1,028 Answers
If washer is leaking lean backward against wall pump is on front bottom ck it for leak most likely suspect can be changed without removing cabinet 2 clips 2 clamps..front and side come off together remove end caps on console by pulling forward and off remove screws underneath roll console back remove the clips underneath unplug lid switch cabinet will lean forward and off
Posted on Sep 02, 2008
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
LAT 7793 ABL model number. Washer leaking during fill...? a seal or gasket but not sure how to remove the spin bars to access it
On Your washer to locate a leak, remove the front panel first. Should be two clips at the bottom of front panel, use a putty knife to pry them down while pulling lower of front panel forward (older models used two screws right through front panel on left and right sides). After getting both lower clips loose, pull bottom of front panel forward to remove from top.
Set front panel aside and then use a 3/8" socket or nut-driver to remove two screws (one each) in the front right and left corners that secure the top to the side panels of the washer (inside in front corners going upwards). After screws are removed slide machine away from the wall about 8-10" and lift front of top up. Will pivot up like the hood on a car. This will allow you to examine machine for leaks.
Let me know when you come up with leak location if you need any more help!!
Jun 30, 2010 | Maytag LAT3600A Top Load Washer
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Wbsr3140 washer leaks
looking at the washer the front panel is held on by clips, take a flashlight and a butter knife and slide the knife in the top crack of the front panel and slide to one side until it stops. this is a clip. usually in line with the washer lid seam. there is one on each side. push in and up on the clip while gently prying door forward, and wala it will open. if you can fill the washer with water alone and it doesnt leak. you probably have a soap issue which can be solved by cutting the soap usage down
May 17, 2009 | GE WBSR3140DW Top Load Washer
2004 Expedition Sun Roof Leaks
you have 2 drains in the front that go down the a pillars and dump near the fenders.
The rear usually go down the B pillar or C pillar and out thebottom near the rocker panel.
Blow them out from the top with compressed air and make sure you have air flow at the exits.. Open the roof to see drain holes in the four corners.
  • The roof opening panel leaks
  • Roof opening panel adjustment.
  • Front rail seal.
  • Drain tube attachment points.
  • Roof opening panel water trough and seal.
  • Roof opening panel drain hose.
  • Roof opening panel seal.
  • Roof opening panel.
1 is the drain hoses
Apr 12, 2009 | 2004 Ford Expedition
My Admiral Washing Machine (5 years old) is leaking.
Isolate the machine, use a knife or thin bladed tool and insert between the front panel and the top panel approx 4" from each side to release the clips, the top should lift up,2 screws at the top inside will release the front panel for a better view.
Apr 11, 2009 | Admiral AW22 Top Load Washer
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Door leaks on the floor in front of my dishwasher
1. make sure dishwasher is level front to back and side to side.
2. check the main washer arm (WD22X154) on the bottom side for leaks. If you use heated dry, the heating elements can cause the part of the spray arm directly over it to soften and eventually leak. When water comes out that leak it can spray at the bottom of the door, splashing water inside it and resulting in your leak.
3. if 1 and 2 OK, watch how you load the lower rack. If dishes or a bowl direct water from the lower wash arm to spray against the bottom of the door, especially at the center of the door bottom, the resulting splash inside the door allows water to hit the outer door panel and drip out a one or both corners of the door.
Dec 07, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 23012 Top Load Washer Logo
105 people viewed this question
Sal De
fordexpert
Robert Rankin
