Question about Bissell 7950 ProHeat Upright Wet/Dry Vacuum
Bissell proheat self propelled series 7950 won't spray water and pump belt isn't broken.
  • luvrpgrl Sep 27, 2008
    Someone put my bissell 9500 series proheat back together, but I dont think they got the hoses/tubes right, as it doesnt spray any liquid. If I remove a hose and then re attatch it, then turn the machine on, for about 20 seconds the indicator showing air flow spins, then it stops and wont start again unless I unplug the tube again and plug it back in, then it goes for about 20 seconds again and stops. Thanks in advance for any solutions
  • Anonymous Mar 22, 2014
    I need a Bissell ProHeat Self Propelled 7950 service manual
I'm having the same issue and it was the pump. The metal drive gear sheared off of the plastic pump shaft. I JB Welded it back together, now I just need a schematic to reassemble the cleaner.
Posted on Sep 27, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Will not sunction water
Your extraction pump is bad. it needs replaced by a Repair center such as Sears.
Apr 17, 2012 | Bissell 7950 ProHeat Upright Wet/Dry...
My Bissell Proheat is not spraying water. What is causing this? and will it be expensive to fix?
It is very simple and inexpensive to fix. All you need to do is replace the pump belt. Here is the belt you need:
Bissell Proheat Pump Belt
May 20, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat 8910 wont spray water or solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have a bissel 7920 proheat pro-tech machine but it does not spray water and shampoo
sounds like a pump problem. PIC << click
heres a website that sells it << click
i would also replace the pump belt.
other things to check
tank may not be seated properly.
pump belt may be broken.
filter maybe clogged.
Oct 08, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat only sprays for a few seconds.
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
Sep 15, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My bissell proheat 12 amp will not spray water on to the carpet,nor will the hand tools spray water?
The water is pumped via the belt that drives the pump. Remove the belt pump on the left side of the unit using a screwdriver and prying upward in the slot in the rear of the belt cover. The belt cover has holes in it. Check to make sure the belt is not broken. If it is replace, about $3-4.
Good Luck
Feb 24, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7950 ProHeat Self Propelled Carpet cleaner Replacement Pump Belt part 215-0628
Normally, there is a post sticking out of the retainer to remove it. If the post is broken off, then you will have to lift the black arm and wiggle it at the same time and the retainer will pop up so you can remove it. On the belt side, the retainer is fairly large and you can usually get a hold of it with a pair of needle nose pliers. On the other side, the retainer is small and you can lift it out with the pliers by griping it gently using the hole that the screw goes through.
Jan 27, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7950 ProHeat Upright Wet/Dry Vacuum Logo
675 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
