Question about Car Audio & Video
Amp hook up
How do i install a amp without the warning light coming on
    Novelist:
  • 100 Answers
If you are referring to a warning light on a car, unless you knicked a wire that caused a warning light to come on. It shouldn't matter if you have an aftermarket amp. If you are referring to a warning light on the amp. Make sure that you are not under driving the impedence and not shorting any wires. If you dont have any shorts, then your amplifier is probably done for. Because you might have a short internally. Unless it is just in protect mode. I had a memphis amp that went into protect mode, I set it off to the side for a for a week or so and was bored so i hooked it back up and it worked. It still works and that was about 2 years ago. Good luck.
-Andrew Hawkins
Posted on Sep 04, 2008
Why does the Engine Warning light come up but other warning lights like battery, oil pressure etc.don't show up in ignition mode & the car doesn't start?
Sounds like a wire was not re-installed under the hood. When the alternator or battery were replaced, there are several power wires under the hood that attach to the same power terminal. Look for a RED wire with a large round connector, that is just hanging out in the open air. You need to install it back onto the post that it came off of. good luck.
May 07, 2014 | 2010 Chevrolet Spark 1.2
SP OFF mode?
if you turned it on without speakers hooked to it you may have blown the speaker output amps or if the end of the amp remote wire touched a ground you may have burned a trace on the board did you here it play at the pawn shop? or did it just light up? sometimes the people at the pawn shop think if the unit lights up it is working and sometimes they check them is just hook power to them without speakers if so this can blow the speaker output I would take it back to the pawn shop
Jan 29, 2014 | Kenwood KDC-MP235 CD Player
'94 Peugeot 205 warning light
hook a OBDII Code Reader and see what it says and your car should have a CAT
Apr 12, 2013 | Cars & Trucks
Can i download ARCSOFT photo impression4.0?
That's probably your only choice until you get a CD drive.
Jan 27, 2010 | Cameras
The service engine soon light stays on. Auto Zone hooked it up the engine show no problems
It is likely a warning that some major maintenance is coming due; for example, timing belt replacement, catalytic converter reaching end of life (typically 60,000 miles) or other. There is probably a procedure for resetting the warning without actually doing what is required.
Oct 07, 2009 | 2002 Ford Explorer
Protect light comes on, no power
Hello patrick_h_mi,
You'll also need a remote turn-on source for the amp to operate. Normally, this is a blue or blue/white wire from your head unit, but for test purposes, you just need 12V to the "remote" terminal on the amp. The amp should power up without speaker inputs or speaker connections, but it is not recommended.
Hope this helps.
May 28, 2009 | Infinity 7540A Car Audio Amplifier
WARNING LIGHTS COMING ON
Its about ESP function. normal. Remember sprinter is very fast van but not rally rated.
May 14, 2009 | 2004 Dodge Sprinter
Yellow warning light coming on that looks like exhaust pipe
You need a code scanner hooked up to it to find out why that light is on. If you have an autozone near you,go there they will hook one up for you. Takes about 30 to 40 seconds. If not call around.
Mar 10, 2009 | 2006 Volkswagen Golf
I have a 2001 hyundai elantra and the warning lights on the dashboard. I know what the oil light looks like and the airbags. What are the other two lights.
Your best bet is to go HERE and signup for a free account then Downloading your Manual - service sheets, diagrams, parts lists etc.
Hyundai is one of the best with providing their customers with free information about the vehicles!!
I have D/L the manual, and the warning lamps on the instrument cluster are...
Left to right...(starting under temp. Gauge)
WITHOUT TRIP COMPUTER
11. Traction Control Indicator Light (If installed)
12. ABS Warning Light (If installed)
13. Seat Belt Warning Light
14. Oil Pressure Warning Light
15. Charging System Warning Light
16. Parking Brake/Brake Fluid Level Warning
Light
17. Malfunction Indicator Light (MIL)
18. SRS (Airbag) Warning Light
19. Trip Odometer/Odometer
20. Trip Odometer Reset Knob
21. Low Fuel Warning Light
WITH TRIP COMPUTER
7. Front Fog Indicator Light (If installed)
8. Door Ajar Warning Light
9. Trunk Lid Open Warning Light
10. Parking Brake/Brake Fluid Level Warning
Light
11. Malfunction Indicator Light (MIL)
12. Charging System Warning Light
13. Oil Pressure Warning Light
14. SRS (Airbag) Warning Light
15. Cruise Indicator Light (If installed)
16. Seat Belt Warning Light
17. ABS Warning Light (If installed)
18. Traction Control Indicator Light (If installed)
19. Automatic Transaxle Position Indicator Light
(Auto T/A only)
22. Low Fuel Warning Light
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 21, 2009 | 2001 Hyundai Elantra
No power to subs
I think the blue wire is a standby "on" to be hooked to separate or system switch. Without knowing how you have system wired, I can' offer much. A bit of caution; having a thousand watt amp hooked to 6x9 dooms their fate
May 06, 2008 | Legacy Audio Blue Diamond LA1880 Car Audio...
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
