Question about Intertherm P3RA-048K Air Conditioner
My blower heating up and shutting off
When my air cuts on it runs for bout 15 minutes gets hot and turns off
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Sound like it needs a service call.
Posted on Sep 03, 2008
Everstar portable air conditioning model number
check for dirty condenser coil the condenser hot air will be very very hot more than 30 degrees higher than what is going in
Sep 12, 2014 | Heating & Cooling
My AC unit runs for 15 minutes the cuts off. Then there is no
Hello, if there is a condensate safety switch this will cut off power to the tstat if the comdensate line is backed up. Check the condensate line to make sure it is clear.
May 06, 2012 | Heating & Cooling
We turned on our a/c unit and the fan outside came on but only for about 15 minutes and then stopped. We cut it off and waited for a little while and cut it back on and it did the same thing. We replaced...
When it cuts off, there is still power to the fan motor then replace the motor...you can check for power going to the fan right in the electrical box of the condenser...
My idea of this would be that the motor gets hot and then cuts out, or the bearing seize up when hot...
heatman101
Apr 27, 2011 | Goodman CKL30AR30 Air Conditioner
Hard start when engine hot
Clean the temperature sensor wire connector.
Replace the temp sensor.
Check the condition of the sensor wire cut(s) or short onto the engine block.
Monitor the fan operation with the hood open during warm up (0-15 minutes.) It should ran after the engine coolant temp get above 195F +.
Check,clean or change the air filter and breather element.
Dec 13, 2009 | 2002 Kia Sportage
After the car gets hot it wont stay running and looses all of its power dont wanna go and when it dies it takes 30 minutes to get it started again
Inspect,clean and change air filter and breather element.
Dec 08, 2009 | 2001 Saturn L-Series
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
97 altima a/c problem
check for the freon charge level.if the freon is too much definitly your compressor will turn and off every 10 seconds
Aug 07, 2008 | 2001 Nissan Altima
Peavey impulse 1015 horn cuts in and out
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Jul 27, 2008 | Peavey CH1 Speaker
The compressor only works about 15 minutes
This unit could very well be over charged with gas and when the unit runs for about 15 mins. the pressure gets too high and cuts off on high pressure if your system does that so many times the compressor will get hot and shut off on internal over load, And will not come back on till it cools down. .... Or you may have a kink or restriction in your refrigerant lines somewhere... this would cause your compressor to also run hot and cut off on internal overload.
Oct 15, 2007 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
46 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
