Question about Garmin Nuvi 760 Handheld GPS Receiver
Not powering on
My garmin 760 will not power up at all. When i have it plugged in the top light on the charger is blinking and it is orange. What do i need to do
  • 1 more comment
  • tomcara3rd Sep 08, 2008
    after doing updates. wont boot up. just cycles thru black "Garmin" screen over and over. tried letting battery die, tried full charge. neither reset work
  • Anonymous Oct 30, 2008
    After last update the device worked for half hour and then froze. After this it starts shows the black garmin display up loading maps and shut down.
  • tomfahy Nov 02, 2008
    Will not power on. I left the device in its cradle with the charger plugged in. I turned the device off, and when I tried to turn it on a couple of days later: nothing. Ditto when I connect it to my PC.
You can try a master reset: press and hold the lower right corner of the screen and power it on. You should get a message asking if you want to delete user data just say yes.
Posted on Oct 06, 2008
The orange light blinks a couple of times then goes off and after that the green power light blinks once with the antenna light
Blinking orange lights means no power or low power. Not enough to power the laptop. If it is plugged in and still the same, then your charging port or charger is damaged.
Mar 03, 2014 | Acer Aspire 5050-3371 Notebook
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Garmin 760 won't power up and is hot.
Have you tried sliding the power switch to the left and holding for at least 30 seconds?
- Jim
Aug 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
I have a Garmin 760 did not come with a ac
The AC charger plugs into the mini-USB port on the bottom of the unit. The term AC is somewhat misleading as the AC charger plugs into an AC outlet but provides +5VDC to charge the units internal 3.7VDC battery.
You can purchase an OEM AC charger here:
http://www.sharc.net/gps_repair_prices.htm
- Jim
Aug 23, 2009 | Garmin Nuvi 760 Car GPS Receiver
Where do i plug in my 120v charger on my garmin nuvi 760 gps
Hi I have this model too. You must have the 120v charger with the Mini-B  port on it. It plugs into that port on the bottom(PS3 controllers cameras, and other Computer devices often have a mini-B USB
Apr 04, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin 750 gps will not turn on when plugged into power source
A dead battery will cause the unit not to turn on, but it should turn on if connected to an external power source like an AC wall charger or DC car charger.
- Jim
SHARCNET-USA
Mar 05, 2009 | Garmin Nuvi 760 Car GPS Receiver
Garmin 760 wont come on
Try holding the power slide to the left and holding it there for 8 seconds. If that doesn't work, try charging it via your PC & USB cable. If that doesn't work, try a mains charger if you have one (I had to do this with mine). Good luck!
Dec 31, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
No power
Slide the power key to the left 10 seconds.
Update at Garmin.com/webupdater
Jack to Computer and run.
your Software/data is safe.
check fuse in the end of the adapter
Regards.
Sep 02, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
151 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
