Question about HP iPAQ H5550 Pocket PC
Error message while syncing Ipaq
Get a message saying "there was no response while checking for out of date appointments" Then I have to restart. What can I do to sync?
    Master:
  • 450 Answers
Open Activesync on your PC. Click on Tools, Options. Double click on calendar. On this screen is it set to sync 2 past weeks and ALL future appointments?
Posted on Sep 14, 2005
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
I AM TRYING TO SYNC MY HP iPAQ TO MY COMPUTER, BUT AN MESSAGE ERROR SAYS THAT 'RAPI.DLL' IS MISSING. WHERE I CAN DOWNLOAD 'ACTIVE SYNC' AND 'RAPI.DLL'
You can download the Microsoft ActiveSync from:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-download.mspx
This package contains the rapi.dll inside it.
Note: Microsoft ActiveSync is for windows XP and earlier version only. In case of Microsoft VISTA download Windows Mobile Device Center.
Jul 11, 2009 | HP iPAQ RX3115 Pocket PC
Sync PDA problem
Uninstall the Mobile Device Center. Be sure to download and install the LATEST from Microsoft. Make sure your device is NOT connected until after installtion. DISABLE all firewalls for a 15 minute interval. Then just plug in and you should bet set. When you reboot you should be good you may get a pop-up from your firewall, just allow it.
May 20, 2008 | Computers & Internet
IPAQ 6965 problem
Go to \Windows\StartUp and delete the offensive program.
May 13, 2008 | HP iPAQ hw6965 Smartphone
New sudden sync problem PDA with laptop.
got start> programs > active sync> open> then connect the usb cable...after phone is detected try to do sync. reinstall active sync can also help.
Oct 02, 2007 | HP iPAQ HX4700 Pocket PC
Deleted appointments
Problem was solved by HP folks! talkinglens!
Sep 12, 2007 | HP iPAQ HX4700 Pocket PC
IPAQ 3955 Won't Sync?
Try uninstalling, rebooting and reinstalling ActiveSync on the host. If you haven't yet upgraded to 3.6, maybe upgrading will clear up the problem.
Sep 12, 2005 | Compaq iPAQ H3955 Pocket PC
Delete calendar
Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Don't forget to change these settings back.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Unresolved Items when synching
Try the following.... Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Now go back in to those Calendar settings, and set it back to the default which is 2 past weeks and All Future appointments. SYNC (this will now reload all appointments into your Ipaq)
Sep 08, 2005 | HP iPAQ H2215 Pocket PC
HP iPAQ H5550 Pocket PC Logo
65 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
