Question about Canon BJC1000/CanoScan FB320 InkJet Printer
Canon S100SP Hi there. My Canon S100SP is not printing anything. I just bought it NEW SET of INKS, but when the paper comes out, there's nothing on it. Can you help me out on my problem? Thanks in advance.
  • rilthelord84 Dec 25, 2008
    i need to install my canon s100sp printer plz
How to download a s100sp driver
Posted on Sep 29, 2008
I have a Canon I9950 printer it started playing up and despite head cleaning in warm water etc as recommended still did not print all the colours. I bought a new print head and new canon inks (always used...
I would check to make sure that the contacts on the cartridgew sensors are not fouled with dried ink. A q-tip with rubbing alcohol should help to remove the dried ink if that is in fact the problem.
Oct 19, 2013 | Office Equipment & Supplies
MP530 all in one printer - bought Staples magenta & blue inks but printer won't print those colors but did print older Canon inks not needing replacing; bought new Canon magenta & blue inks but...
What you can do is take the ink cartridges out of the print head and remove the printhead. Hold the print head over a trash can and take some 409 cleaner and spray the little pads inside the print head til you start noticing the colors dripping into the trash can. You will them want to dry off the print head as much as possible and litely wipe off the outside and the bottom of the print head with a paper towel. Then reseat the printhead back into the printer and the inks. You will then want to run a nozzle check from your printer software or from the printer properties. If the inks still are not showing up run one or two cleanings. If the issue still persists then you might have to replace the printhead. If this is the case you can look up part number: QY6-0059-000 online to replace the print head.
Jun 30, 2010 | Canon PIXMA MP530 All-In-One InkJet...
A paper jam message continues no paper in machine. started when printing an alignment page after new cartridge.
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
Canon IP4200 printed great photos when new. My
Although refill inks can be quite good, it is likely the cause. Several companies do make good refill inks for canon but they are specific to model lines and you have to be sure you get the right ones for photo colour.
The inks you're using are likely "universal" inkjet inks and are fine for everyday printing but are rarely ever colour corrected properly for photo.
My recomendation to all of my customers is always to keep a new cartridge handy for photos but to use the refilled ones whenever they are printing anything else as it will give you the best balance between print cost and print quality.
Chris
May 18, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Horrible print quality
hi i am a certified Canon repair tech for this printer. the first problem is the paper you are using hp photo paper is specialty formulated to be used with there inks. every manufacture is the same if you want the proper looking photo and you are using a Canon printer you need to use Canon photo paper because the paper is formulated for their inks. hope this helps to clarify.
Jan 04, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Canon BJC1000/CanoScan FB320 InkJet Printer Logo
511 people viewed this question
old marine
old marine
