Question about Garmin Nuvi 660 GPS Receiver
Satellite and power
The unit will not retrieve a satellite signal and powers off on its own. What can I check. I have never charged the unit but it has received little use lately.
thanks, ks
  • uts3 Sep 05, 2008
    same here..starrted in Augst..whats the deal?
    even asks me if i'm the correct state?
  • 53 Answers
The internal sat antenna in the unit is broken or your unit is undercharged but i am sure it is the antenna this series of garmin are known for this problem.. you will have to send the unit into garmin unless the store you bought it from has a protection plan hope this answers your ?
Posted on Sep 24, 2008
I don't have Satellite signal! I tried to acquiere satellite signal with my Garmin Nuvi 1350! The screen always says locating satellites but nothin happens! The satellite bars are not green!What can I do...
Try fully charging the unit and leaving it stationary for about 20-30 minutes if you still dont lock satellites try giving the unit a firmware updates using Garmins WebUpdater software here is a link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Hope this helps!
Feb 24, 2011 | Garmin nuvi 350 GPS Receiver
I lose satellite connection every time I turn on my GPS unit. After few minutes connection will be restore by itself. Why this happing and what can I do to fix it. Frank
If you shut the unit down - and remove it from the power cord in your car, this is expected.
When powered down, the unit is not capable of maintaining contact with the satellites in the sky. When you power it up, it needs to receive signals from 3 or more satellites get a "fix" or calculate your position in the world. The more signals received, the the more accurately displayed your position will be. The device must use the signal data, perform calculations and bring up a map of your area.
The "Lost Satellite Reception" message also occurs whenever the GPS does not have a clear view of the sky over the earth's equator. This can be from a garage roof to heavy foliage (tree cover) - and even when driving between tall buildings. Usually, it shouldn't take more than a minute or so (once the obstructions have been cleared) for the GPS to reacquire the signals, calculate and display your new position.
I hope this helps!
Oct 27, 2010 | Garmin nuvi 255W GPS Receiver
Our tomtom one gps does not receive signals and becomes dead often.
Bad connection on the power supply may be the problem and this will not allow the unit to charge fully. Bad battery time for a replacement battery. No satellite? Try moving the unit down towards the defroster vents and keep it so that it is close to the front windshield. If these units do not have a clear view of the sky they will never find the satellite and you will always be frustrated with it. Hope this helps
Jun 15, 2010 | Tomtom ONE GPS Receiver
Recently when returning from a trip my C550 giving keptme the message "satellite unable to locate" (not the exact words) This went on for a week or more but suddenly started locating me from the satellite....
Low battery power is generally r4esponsible for loss of signal or low signal. Charge itr fully before use and plug into car power source ONLY AFTER staring the engine so as to avoid spike deamage. The car charger cannot fully charge the battery it is justn sufficient to maintain a level of charge . If the battery gets too low it cannot maintain a constant signal.
Jul 24, 2009 | Garmin StreetPilot c550 GPS Receiver
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Clock reset and cant find satellite
I have had the same problem. I just notice the power switch on the bottom of the unit. I believe if this one is used it will not lose power. The other power button is probably for a standby mode.
Oct 21, 2008 | Sanyo NVM-4050 GPS Receiver
Garmin Nuvi Firmaware Update Complete, Unable to catch satellite signal
Same here - garmin nuvi 310 - bought it last year around March, said dowloading gps and then can't get a signal/satellite?? Will phone garmin tomo
Apr 18, 2008 | GPS
IPod and Sirius hook up
allpioneer products need power and ground to operate. check the fuse on the yellow wire. if ipod is not plugged in, it will not show as a source on the pioneer head unit
Oct 28, 2007 | Pioneer SIR-PNR2 SIRIUS Radio Receiver
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
Power but no signal
I am running into the same exact issue. I have had my Sportster about 14 months now and this is the first problem I've encountered. We had a cold night in the low 20s and the next morning the Sportster started in with these issues. It's been two weeks now and I have the same exact issues (have power, all connections in tact, no "no signal" message, etc.). Sirius recommended a factory reset through the menu option. I was able to do that, but the problem was not corrected. If anyone has any advice here, please let us know..... Thank you. -Peter
Jan 12, 2007 | Sirius Satellite Radio Sirius Sportster...
Garmin Nuvi 660 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
