Question about GPS
I have a nuvi 350 and the on/off button is not working - I press hard but nothing... any ideas?
  • yywang00 Dec 30, 2008
    when power pressed, it jumps to a screen showing "press dot" and the device is dead. I tried to press "reset". It still does the same thing.
  • GPS Master
  • 2,130 Answers
Please read this article about your Nuvi problem. I can help you fix this. Email me at ks3r @ sharc dot net - I have repaired many units with this issue.
http://www.fixya.com/support/r953237-garmin_nuvi_off_power_switch_problem
- Jim
Posted on Sep 03, 2008
Konica Minolta C652 Fax/Scan Button and User Box Button
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
Jul 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
The Garman works when out of the vehicle but when in the vehicle the Garman reads "cannot detect satellite"
try reseting the unit - the reset button is under the antenna.Keep in mind that satellite acquisition is only possible outdoors or in a vehicle. Last case scenario try a hard reset (will erase all your saved places and bookmarks) - hold your finger on the upper right corner of the nuvi's screen while turning on the nuvi keep your finger pressed until the popup window appears - touch yes to clear all user data.
May 25, 2010 | Garmin Nuvi 350 Car GPS Receiver
GPS - Garmin Nuvi 350 has mind of its own
Reset behind Antenna, press this in
and update it at Garmin
Should be good.
Regards
Ric.
May 16, 2009 | Garmin nuvi 350 GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 350 Calibration Issue
Turn the unit off. Press and hold down the power button and keep holding it. You will see the screen light up and it will say "pre-boot mode". Keep holding down the power key. It will then say "booting". Keep holding the power button down. You'll then come to the calibation screen. Select the dots and you'll be back in business.
- Jim
Oct 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Touch Screen
Did you press the reset button locate under the antenna?
Aug 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 on off problems
This is a common problem with the Nuvi series. The on/off switch is a surface mount switch that is mounted vertically off of the main PC board.
The problem is, that there is no support behind the switch, so when you press down the button, the solder leads of the switch are stressed and eventually break off the main PC board. This is a design flaw and could have been easily prevented by wedging a small piece of plastic between the rear of the switch and the SD card housing to give the switch support.
Also, the solder pads for the mechanical connections of the switch could have been made bigger, allowing for more surface area and more solder application.
I have repaired many of these before and I'll be posting a step-by-step procedure on how to fix this and prevent it from happening again.
I must point out however, that in order to make this repair, you will need to have skills in dissassembly and soldering.
Also, please only attempt this procedure if your unit is out of warranty.
If you would like for me to repair your GPS, please email me at KS3R at sharc dot net.
- Jim
Jun 22, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
375 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
