Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Model 9p6034c102 picture going out
My picture will sometimes be real red and fuzzy around the outsides, sometimes it will split screen and be fuzzy. Sometimes I can turn it off and on and it will be fine other times it will continue to be bad. Its like the picture is going out. Any help?
  • 2 more comments
  • dkschoolmees Sep 08, 2008
    I have a similiar problem, though i am getting red and green across the screen which seems to move around or split. And is also fuzzy. What is the problem? We re booted the tv, though did not help. Help.
  • aadams68 Sep 12, 2008
    I have sound and video. I am getting the red and green as well and it sometimes rolls or moves around. Other times the picture works just fine. Its seems like the picture is in the begining stages of going out. Any help with this???
  • aadams68 Oct 05, 2008
    I finally broke down and called a repair man out. It was my cooling fluid in the blue tube. He ended up changing the blue and green . Cost me about $300 better than buying a new tv. He said it was common on the philps magnavox . Hope this helps
  • aadams68 Oct 14, 2008
    Mainly just blurry and red and green. I also had to have them back out cause it was doing it again and this time they replace something on the circuit board. Not sure what it was though cause the wife was dealing with it.
  • Philips Master
  • 3,459 Answers
If you have no sound or video or if your screen keeps shrinking and expanding its typicaly the opto chip. You can get the chip and repair instructions from www.magnavoxhelp.com . This is a fairly common problem.
Posted on Sep 07, 2008
  • Edward
    Edward Oct 05, 2008
    Thanks for the update aadams68! It's amazing how many people post their problems on this site but never bother to post when or how they fixed their set.
    Question: You first stated that the picture was going in and out? Was it shrinking or expanding or was it just real blury?
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
My rca hdtv has 3 split screens
T con board responsible for images on screen. If they are messed up, check this board out or replace it.
Aug 23, 2017 | Televison & Video
Our Phillips flat screen TV picture is split down the middle vertically. One side shows a mirror image of the other side, and then sometimes one side is a lighter shade than the other, when it is full...
This may be due to a faulty Timing Control board (TCON board). I had a similar problem with my Samsung LCD TV picture being split vertically down the middle. The image on both halves appeared fuzzy and in reverse (mirror) including the menus. I replaced the TCON board and the problem was resolved.
Aug 18, 2011 | Televison & Video
I have a WD 65831 Mitsubishi television. I love it and have had NO problems so far with it. The picture and letters on the screen seem slightly fuzzy (out of focus). I had the bulb burn out and I replaced...
Projection TV sets have two very common problems oulined below.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio/Video - TV Makes Chirping Sound
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 24, 2010 | Mitsubishi Diamond WD-65831 65" Projection...
My lg kg800 chocolate phones screen is broken
I would recommend that you get your screen replaced. You can find some replacements on Ebay or visit any phone shop and they can estimate the cost of repairing the screen
Oct 24, 2017 | LG CHOCOLATE VX8500 Cellular Phone
HP Plasma Tv Black picture
This sound likes the Y-board that controls the video was defective. This is quite common problem of plasma as the TV gerenates lot of heat.
Aug 13, 2009 | Televison & Video
Problem with split screen
YOUR SET HAS 2 TUNERS IN IT IF YOU SWAP THE PICTURE DOES THE PICTURE ON THE RIGHT SIDE REMAIN FUZZY?
IF SO YOU NEED THE PIP TUNER REPLACED OR REPAIRED.
EST $400-$500
30YR SERVICER
APGONZO
Dec 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Can`t get clear picture anymore
Hello dhack56,
Can you post a picture of the screen as the TV is playing, this way I can see if the picture is fuzzy, or if the images are split, all of which classify as not a clear picture. A picture of the screen will help with the diagnosis.
Thank you,
Shuttle83
Oct 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
I need a convergence on a circa 1994 50 inch sony projection TV. The Picture is slightly fuzzy and does not go to the edges of the screen. Can I do this myself or how much should it cost?
The repair shop will charge around 400.00 however you can do the repair yourself real easy just go to this link and click on contact button and leave your model number by email and they will tell you the correct ic to get and if you get it from there they will also give you free installation instructions as well as free online support
http://servicemanuals.vstore.ca/
Apr 09, 2008 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
229 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
