Question about Dell Axim X5 Pocket PC
Help with Avantgo
I just received my Axim, and this is one cool machine!! However I ran into a problem with Avantgo. I first install active sync on my home computer and under detais I have avantogo listed, and it sync's perfectly. I then install active sync on my work computer, but avantgo doesn't sync, and it isn't listed under details. How do I configure it to show up on my work PC
    Master:
  • 852 Answers
Did you install the avantgo software on your work computer too? I would think it would need to be installed on every computer you want to sync it on.
Posted on Sep 14, 2005
    Master:
  • 852 Answers
You don't really need for it to. You can go to setting on your Axim, then to connections, and use the avant go connection, to connect, and synch with avant go that way. You can synch to avant go that way, with any internet connection. If it's connected to active synch as a guest then you can't synch with active synch also.
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
How do I sync axim to outlook?
Try deleting the active sync partnership as mentioned in this post -
http://www.aximusers.com/forum/axim-x51-x51v/6651-synchronize-outlook-contact-problem.html
Jul 17, 2009 | Dell Axim X51v Pocket PC
How to connect Dell Axim X51 with the desktop computer
You need the cradle or the usb cable for the axim and get Active Sync 4 installed on the computer.
Jun 16, 2009 | Dell Axim X51v Pocket PC
Need to find Active-sync program for Dell Axim 51V
I believe Active Sync has been replaced by Windows Mobile Device Center for Vista. I'm not using my Axim any longer but was able to sync it using Windows Mobile Device Center. You should be able to download at :
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center-download.mspx
Hope this helps.
Mar 15, 2009 | Dell Axim X50v Pocket PC
I have installed active sync to link to my aximx51 but it can not detect it
have you upgraded to 4.5 active sync. If so turn off the advance usb function located in setting and then connections. This worked for my axim x51v
Sep 15, 2008 | Dell Axim X51v Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
Connecting Axim plus Palm on the Same PC
I may be wrong but each PDA (assuming you are connecting different brands) have different drivers. I connected a Toshiba and Dell PDA and each required their respective install disk with their respective drivers. Then I configured each pda using the Active Sync Connection Wizard. Everything ran smoothly after that.
Sep 14, 2005 | Dell Axim X3 Pocket PC
NO file transfers are working!
Try deleting the partnership in ActiveSync on the PC, and then create a new partnership. I saw this problem, when I connected the first time to a PC. I tried connecting to a second PC, and had no problem. When I went back to the first, it required that I create a new partnership, and no problem with the connection.
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Avantgo
I am unsure myself after looking at this Pocket PC software matrix. Today I use AvantGo in my HP Jornada under PPC2000, but it seems it is not installed in the PPC 2002 software according to this matrix. Maybe there is a download you have to do, or settings for your server access you have to make?
Dell Axim X5 Pocket PC Logo
126 people viewed this question
Clive
Clive
Alun Cox
