Question about NEC Computers & Internet
I have A NEC monitor that will not light up. - NEC Computers & Internet
    Scholar:
  • 152 Answers
Check if your monitor's power cable is in good shape and inserted firmly at both ends.
Posted on Sep 02, 2008
My NEC MultiSync LCD1970NX monitor went black while in use and green power light is flashing.
If the system is booting up and if you see the "NUM LOCK" key lighting up in your keyboard then the system is working fine. The problem is with your graphic card. Check and repalce it. If not, the problem is with your monitor. Check the warranty and ask for a replacement.
Mar 03, 2011 | NEC MultiSync LCD1970NX-BK (Black) Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I have a nec LCD2070nx Power light is on
Hi:
Your monitor has a problem on its inverter board. It is an electronic component failure, and often it cost's more to fix it than to buy a new LCD monitor .
Nov 23, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC MultiSync LCD2060NX does not power up
Not user servicable and with the low prices of new monitors - not worth the cost of the part.
Oct 29, 2009 | NEC MultiSync LCD2060NX (Bezel) 20" LCD...
My monitors light is blinking all the time n no pic Nec Multisync FP1355
there is a setting you can access from the monitor menu button. make sure that the monitor is set for the cable you have running to it.
If you are using DVI use the digital setting.
Anything else, use the analogue.
Jun 28, 2009 | NEC MultiSync FP1355 (White) 22 in.CRT...
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
Nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem
Mar 05, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC Multisync 1760NX malfunction
I repaired mine by replacing C807, 22uF 50V capacitor in the power supply.
Monitor Mike
Nov 07, 2008 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
Flickering pixels
plug it in all the way thats how i did it
Oct 30, 2007 | NEC-Mitsubishi Nec Display Solutions...
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Computers & Internet Logo
22 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
