Hi Error
code F 35 means ANALOG PRESSURE SENSOR FAILURE. There is any malfunction of the
component detected by the Steamer Electronic Board. Please check whether the
pressure hose is fixed firmly, and the air trap is not blocked. Make sure the
hose is not plugged. If this doesn't resolve the issue then it is a problem
with the water level pressure switch operation. There could be a blockage in
the air dome or pressure switch hose. The air dome is located on the back of
the tub on the left hand side. If the pressure switch hose and the air dome is
clear of any blockages, then there is an issue with the water level pressure
switch, you would need to replace it. Hope
this helps...please post back for further assistance. Daniel
