Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Screen went black, made a squealing noise and smelt like burnt plastic.
Now the TV won't turn back on, and if I press power on the TV, it squeals more.
Not sure if there is any hope for my TV at this point. But, Can someone give me some suggestions?
Thanks
    Genius:
  • 1,239 Answers
Hi sir
if it is in warrenty period.. please cheak it or just open the cover see whether the 250 v coming in the start point of the circuit board and see whether an fuse wire is burnt out , if burnt out replace it and check whether the further voltage comes after step down the transformer.. if it correct & fuse is replaced it wil work. thank sir
Posted on Sep 02, 2008
Why does my sylvania electric fireplace Model S211 squeal
I had the same problem. If you remove the top row of screws on the backside of the unit, you'll see that the flame effect is created by a series of reflectors attached to a rod. Turning on the unit activates a motor that turns the rod. You'll see that the other end of the rod is just a loose end that is allowed to turn inside a plastic holder. Unfortunately, the rod rubbing against the plastic as it turns causes the annoying squealing sound. I solved the problem by wrapping a small amount of paper towel around the rod, pushing the PT into place inside that plastic rod-holder, and spraying it with a little bit of WD-40. I had to remove the entire back panel to get proper access. No more squealing noise (for now)! Time will tell if I need to reapply the WD-40.
Dec 11, 2012 | Sylvania Electric Stove Heater, Black...
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
I have a Toshiba 27AF42 and I get a high pitched squeal after the TV has been on for a few minutes. Any ideas how to fix this? Once I turn the TV and back on again the squeal goes away.
yes. its the horizontal linearity coil resonating. take off back. and while unit is on, take a plastic straw and push on coils in the high voltage area. you will find one that squeals when pushed on, or will stop squealing when pushed on. solder that coil and area. that will fix 80 percent of the time. if you push on it and the squeal tone changes, solder it and silicone it done. fixed.
Nov 14, 2009 | Toshiba 27AF42 27" TV
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
Have a polaroid tv, model 3700 seriel F0600181940001053. WATCHING THE OTHER NITE AND A LOUD SQUEAL CAME ON AND THE PICTURE WENT OUT, TURN IT BACK ON TODAY AND THE SQUEAL IS STILL THERE WITH NO PICTURE..NO...
I have a flat screen polaroid lcd hdtv model 3700, first the sound started to get really loud with a beeeeeeeeep when we turned on and after a while was gone, now it doesnt! we had to put mute and connect the tv to a sorround system to hear it without that crazy noise, and now the colors of the tv are gone too its just black and white when we try to see the dish satelite but if we put a movie on the dvd player colors are perfect we try to conect the ps3 player too but its black and white too. Help what can it be!!!!????
Nov 14, 2008 | Televison & Video
Techman
If you have no high voltage it could be hori output and Flyback Transfomer.squealing noise is a bad capacitor 470uf 16v
Sep 24, 2008 | Televison & Video
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Squealing set
It looks like an output transistor problem. You can't fix it by yourself; you will need to call a service. It will cost you at least 100$, so consider buying a new one good luck
Nov 11, 2005 | RCA F25442 25" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
