Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 9100 power problem?
I found a Dell 9100 at a local thrift store. Upon inspection the unit wont power up fully. The green LED light on MOBO lights up but nothing else. First thought was a bad power supply, so I installed another one, still nothing. The system doesnt beep, and no other lights come on. Wondering what could be next to troubleshoot.
  • kurlelox Sep 02, 2008
    dell tech told me to buy a new MOBO but before I drop the $$ is there something cheaper and less obvious that Im missing?
  • 3,940 Answers
There are three components to the Dimension 9100 power system. The power supply, the motherboad and the I/O adapter board.
You can get an I/O Panel here:
http://cgi.ebay.com/DELL-F8913-DIMENSION-9100-FRONT-I-O-PANEL_W0QQitemZ200247697428QQcmdZViewItem?_trksid=p3286.m20.l1116
Motherboard here:
http://cgi.ebay.com/DELL-XPS-400-MOTHERBOARD-cn-0fj030_W0QQitemZ290257206473QQcmdZViewItem?hash=item290257206473&_trksid=p3286.c0.m234
Posted on Sep 03, 2008
I have a dimension 5000 desktop, when I turn on I get a short burst on screen saying DELL, but then a blank screen. I hear a continuos beeping tone and all lightss on front of unit are dispalyed. Please...
Well if its a dell monitor also, it will say dell, and does not mean the computer is communicating with it, your manual is here ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_dimension_desktops/dimension-5000_Owner%27s%20Manual_en-us.pdf (copy and paste) what EXACTLY is the beeping code doing, the term continuous beeping tone could mean different things. You should have 4 small led lights on the rear that say A, B, C, and D that are diagnostic lights, what color are those?
Jan 06, 2014 | Dell Dimension 9100 PC Desktop
The power LED light is orange instead of green and it won't turn on
Hi! for most dell machines if the power led is orange its an indication of a issue with the ram, try to reseat the ram first.if that doesnt work normally for dimension 4600, there are diagnostic lights that are located at the back panel of the machine, they are four bicolor lights(amber and green) You can determine the exact problem by checking these lights and you can interpret them by going to this website: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/adtshoot.htm#1112886 hope this helps...
Jun 12, 2010 | Dell Dimension 4600 PC Desktop
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
I have a dimension 9100 that will not boot. I get
try a new cable for the hard drive and disk drive and see if no result try diferent hard drive please thanks
Oct 22, 2009 | Dell Dimension 9100 PC Desktop
Blinking amber light with green 4 light
If the power light is blinking amber, the computer is receiving electrical power, but an internal power problem might exist.
Try, unplugging the power cable from the pc, and reinsert it, if this does not help try a differnt power outlet, if this dont help, open the computer, take the power Molex conector out of the mother board and try turning it on, if this dont help, take out the Memory modules and reseat them, if this dont work you may want to ring up dell support.
Hope this helps!
Jun 15, 2009 | Dell Dimension 9100 PC Desktop
DEMENSION 2400 WONT POWER UP
It sounds like the power supply went.
Take it to your local computer repair shop for repairs.
Good Luck.
Mar 13, 2009 | Dell Dimension 2400 PC Desktop
Flashing amber light
Flashing amber is normally a failed power supply. So replace the power supply ($50 to 100 depending on the size you buy) Recommend 500 Watt or higher.
www.newegg.com
www.zipzoomfly.com
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
My Dell 9100 desktop won't start.
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Feb 11, 2009 | Dell Dimension 9100 PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
544 people viewed this question
Alun Cox
