Question about Canon GL2 Mini DV Digital Camcorder
Using Clearscan function on GL2
I am recording live music where stage lighting has a faint flicker. I assume they are fluorescent.
I followed my GL2 instructions to take the exposure out of auto, and either use it in Manual or Shutter priority.
However, when I enter the menu to select the proper frequency, the Clearscan function is still not available.
What am I missing to be able to use this feature. Any help would greatly appreciated.
SOURCE: auto exposure not working
Hi, how long have you had your camcorder? my reason for asking is that i have the same model, and recently had to send it back to Canon who were recalling camcorders with image problems as there were a batch of faulty CCD cards Good luck
Posted on Jun 19, 2007
SOURCE: Can't adjust shutter speed in Tv shutter-priority mode
Download a recent firmware,dude. :-)
Posted on Oct 07, 2007
  • 18 Answers
SOURCE: Canon Digital Rebel bracketing
Do you have the dial set to either P, Tv, Av, M or A-DEP? It will only work in those modes, and will probably only be in the camera icon menu when the camera is set to one of those modes.
Hope that helps.
Posted on Feb 24, 2008
SOURCE: can't get my Cannon zr 90 to work, there's a flashing red light in viewer
yes, I found the manual downloads on Canon's webpage. I wish I could figure out how to transfer my tape videos to a computer. I bought the $50,00 DV-1394 cord and nothing happens--computer doesn't recognize the camera.
Posted on Mar 24, 2008
  • 203 Answers
SOURCE: Deleting a scene
you can only delete on a rw disc-r disc won't delete and that may be why there is no option
Posted on May 26, 2008
Canon GL2 mini DV Camcorder
well it seems that the recording head was damaged or in the stage that it was not functioning normally, the best way is to replace the recording head of the device..
Jun 26, 2008 | Canon Video Cameras
My fluorescent shop light fixtures sometimes does not go on and sometimes the bulbs just flicker without giving much light. What's wrong?
If your shop is in your garage, and it is cold outside, the two-pin fluorescent tubes don't work very well. Garage lighting (fluorescent) should be the HO (high output) type. It operates on the same voltage. The tubes are not interchangeable. You need a HO fixture. If your shop is inside your house, then flickering tubes (assuming that you tried changing them out with new ones) indicate a bad ballast inside the fixture. You can either change out the ballast, or for almost the same price, replace the fixture.
Sep 19, 2014 | Home
Oxygen 49 midi controller switches itself off when pressing "record" button on Ableton Live
Make sure only the midi input is set, not the output, and that the channel your using is armed. Otherwise the signal won't get through in record mode.
Apr 28, 2017 | M-Audio Music
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Recording w mic
Hi on1site
Something you may have to try.
if the unit has level controls for gain, sometimes, you can get enough gain through the standard stages to record, particularly if the music is LOUD:). Record live to tape, drop it into a computer and run a compressor over it to pull the gain up to a decent level. Use the best mics you have is also another tip to good recording.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Jun 25, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
TV flickers when turned on
this sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Jan 16, 2008 | Polaroid FLM-3201 Television
Fluorescent light that keeps flickering
The ballast is a device that utilises and expanding/contracting electromagnetic field to create the high voltage which is needed to run fluorescent lights.
It is normally found behind the front cover or reflector part of the fitting and looks like a small box.
Replacement should normally be done by a person qualified in this field.
Oct 26, 2007 | Sea Gull Lighting Sea Gull Energy Saving...
Canon GL2 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
