Question about Ricoh Aficio 1018D All-In-One Laser Printer
My ricoh aficio 1080 can not com with the network, and a red light appear in the connection of the network cabel
And a red light appear in the connection on the network cable.
    Problem Solver:
  • 5 Answers
Chic the IP adress of the machin & the pc
Posted on Oct 19, 2008
Why does Ricoh aficio 4001 pcl6 appear offline?
Check the connection to the machine. Otherwise the IP changed on the machine or the network you're on IP changed.
Jun 12, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Connect a MacBook Pro laptop to Aficio MP4500
do you have post script installed in this printer? if not you will not be able to print from a mac.
Oct 03, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Mar 23, 2009 | Ricoh Aficio 350e Printer
I have a aficio bp 20 series pcl 6 printer its failing to print.
Is it only the 'red' light or is there another one also lit?
If it is on steadily, it should be related to a paper jam, if blinking, then related to Data in, and no paper.
Manual is here to check what the status lights mean (copy this link into your address bar):
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/bp20n/bp20nen.htm
** info is on page 6.21
Feb 18, 2009 | Ricoh Aficio BP20 Laser Printer
Ricoh Aficio 220 - Connection with computer
Please use the link below and scroll down to choose your Operating system, and download and install the printer driver.
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=241&ricohmodelid=5&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fhtml%5Fre%2Fmodel%2Faf22%5F27%2Faf22%5F27en%2Ehtm
Hope you have a printer controller type 270 installed on your Aficio 220, already.
It can be connected with a parallel cable or ethernet cable if you have a network card installed in the printer controller of the Aficio 220.
Good luck and please rate me, thanks.
Jan 24, 2009 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio 1018D All-In-One Laser Printer Logo
879 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
