Question about HP iPAQ RX3715 Pocket PC
Data access problem with SD card for rx 3715
Files on my SD card seems to be corrupted as i can't access some data from the card after i copied them from PC to the card, either via card holder or directly via iPAQ. Data seems to be transferred to the card but i simply can't retrieve them. I checked the card and it seems it's okay. Any possible reasons ?
    Master:
  • 450 Answers
SD cards can be tricky. One good program that I like is pocket mechanic..... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Posted on Sep 14, 2005
My system is not reconizing my sd card
FIRST attempt to use the SD card in a different device /SD card reader like a phone, camera, printer or third party card reader. You need to find out whether there is a problem with the card or the reader is if the other device can see it access files or save files to the card and seems to be working correctly then it's probably a reader problem could possibly be drivers or the reader it's self. It could also need to be reformatted in order for your device to use the SD card. The other possibility is that the card has gone bad and then you will not be able to get it to work no matter what you do it does not take much to damage one of the SD cards.
Jun 01, 2017 | Computers & Internet
Tip
Overcoming with SD card "write error"
SD cards are flash memory devices which allow a user to store huge amount of data. Being reliable and durable, these cards have become the hot choice to store data and are used in various host devices like digital camera, PDAs, video game consoles, MP3 players etc. Despite so many advantages, these cards are also prone to errors. Most of these errors occur due to reasons like interruption in read/write process, virus attacks or file system corruption. While some SD card errors can be dealt by cleaning the contacts of the card and re-inserting it, others can be rectified by formatting the card. After formatting, the SD card data can be retrieved by using either a valid backup or SD card recovery software.
Consider a situation, you have taken your family to an exotic locale and while clicking pictures through your digital camera (which is using a SD card) you witness an error on its LCD screen:
“Write error”
The above error is not rare in case of SD cards. The moment the error erupts, the data stored on the SD card becomes inaccessible. Moreover, the SD card becomes useless as you can't even store new data on it.
Cause
The above error which rendered the SD card ineffectual can be accounted to corruption. The other reason can be relatively less memory space to accommodate new data.
Resolution
In order to rectify 'write error', you can try the following possible techniques:
  • Turn the camera off, re-insert the card and then turn it on again
  • If you are still not able to access the data, connect the camera to a computer
  • You can use a card reader to access the SD card data
  • In grim situations where nothing of the above works, format the SD card and restore the data using a backup
After formatting, the SD card becomes functional and can perform read/write operation. If a backup of the data is corrupted or invalid, you can rely on a SD card recovery software. A SD card recovery tool employs improved scanning algorithms to extract data in the event of corruption.
Stellar Phoenix Photo Recovery, a well-known SD card recovery tool, is designed to recover lost/formatted/deleted multimedia files from a variety of memory cards like SD, SDHC, XD, MMC, CF etc. The easy-to-use tool is available in two versions, one each for Windows and Mac operating system.
on Apr 27, 2010 | Computers & Internet
Can you recover pictures from a corrupted PNY SD 512MB card? If so how?
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is asoftech photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Aug 22, 2011 | PNY 2GB microSD Memory Card
All accidentally deleted.
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
Feb 04, 2011 | PNY 2GB microSD Memory Card
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
One day my SD card was fine and full of pictures and now when I put into my computer it says that the SD card is corupt and can not read it. Can you help me recover the pictures from this SD card?
You may need to try some photo recovery software to rescue the pictures, here are some for your option. You may not recover all the pictures, but will recover most of them.
Photo Recovery (for Windows)
Photo Recovery for Mac
Both programs are able to recover pictures, videos and music files.
Note: Before your files are recovered, do not attempt to save more files to the memory card or stick in case the original lost files are overwritten.
Nov 07, 2010 | Lexar SMC TIGER ACCESS MINI GBIC 1000BASE...
N70 Cellular Phone: how to recover corrupted memory card...
First of all, you should stop saving any new files to your Nokia N70 ( or memory card) or taking new pictures.
Then find some photo recovery software from the following websites, which are able to recover deleted or formatted photos and movies from cell phone, digital camera, memory card and SD card etc. It also recovers photos from corrupted memory card.
Digital Photo Recovery for Windows
Digital Photo Recovery for Mac OS X
Here are the steps:
Step 1: Download and install the Digital Photo Recovery Software.
Step 2: Connect your corrupted memory card to your PC or Mac.
Step 3: Scan the source drive where your lost pictures located.
Step 4: Recover the lost pictures and save them to another drive instead of the source drive.
Best regards!
May 16, 2010 | Nokia N70 Cellular Phone
I have a Nokia 500 gps system. The sd card with
Try to fix the sd card with some recovery software (recuva or similar) and transfer the data to a new card. If you have the installation disk, use that to copy the data to a new card. Do not use the corrupted card, since you might lock up the device for good.
Jul 14, 2009 | GPS
HP iPAQ RX3715 Pocket PC Logo
113 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
