Question about Dell Inspiron 6400 Notebook
Dell inspiron 1525
I just purchased this laptop last night, it has a wireless card built into the laptop and it also has the option for an ethernet port on the other side. i dont have wireless internet so i figured since it has the ethernet port i could just plug in my ethernet cable from my modem to my laptop and it would work..but it didnt i currently have armstrong zoom 500 and i use that for my desktop at home so i know it works. since i bought this laptop i took out the ethernet cable from my desktop and plugged it intomy laptop but the laptop doesnt recognize it. i called my internet service provider and he reset the modem for me and it still doesnt work..please help. thank you Dell Inspiron 1525 Notebook
connection says limited connectivity. was working fine and now this. Had technician with internet service provider come out and he could connect with his laptop, with no problem. Told me Windows Vista had problems with wireless. Contacted Dell and they want to charge me to fix it over the phone, something about doing something to the router. Help.
  • kairw2 Nov 23, 2008
    The first part of the problem is not mine. I don't know how my message got attached to another. My problem is at the bottom after the first thank you.
    Scholar:
  • 155 Answers
To get it to connect wirelessly all of the things in bold must be true.
1. The wireless card driver must be installed and enabled.
  • Go to start>right click Computer>click Properties>click Device manager. Click the plus next to Network Adapters and you must see your wireless card listed under it. If you see the wireless card listed with just a green icon beside it, proceed to no. 2.
  • If it's listed with a red X, right click it and click enable.
  • If it has an exclamation or question mark, click this, choose your wireless card, download and run it, go through the installation. Restart the computer when done or when you're prompted.
  • If the wireless card is not listed under 'Network adapters' check is you see 'network controller' under 'OTher Devices' which is another category in the list. If you see it, click this, choose the model of the wireless card and install the driver.
  • If you arent sure of the model, click this and enter your service tag (on the bottom of the laptop), look for an entry with 'CRD, WRLES' in the part description and you'll find the model number along that line.
2. The wifi light indicator on the right edge of the laptop (near the front) must be solid blue.
  • If the light is not blue and you have made sure Item no. 1 is true, check the slide switch just right beside the light. It must be set to the middle or On position.
  • If the light wont turn on, although the the driver is enabled and the switch is set to On, the card could be defective.
Once the light is on, the computer must be wireless-ready. You can try to call your ISP once more so they can walk you through connecting it again. (It's easier for them since they know your router and network details.)
Pls post back if you still have questions. Pls dont forget to accept the best solution. Thanks!
Posted on Nov 23, 2008
  • Rachelle Aviles
    Rachelle Aviles Nov 23, 2008
    Getting 'Limited connectivity' could also mean you are connected to the wireless network but the wireless key/password entered is not correct. Try to reenter it. Depends on the utility you use to configure your wireless connection.
    How to reenter the wireless network profile. Go to Control Panel. Network Center. Click 'Manage wireless networks'. Click on the name of your wireless network and click remove on top. then add it again. Click add and enter the items needed. You may want to contact your ISP if you aren't sure of your network name/ID and wireless network key/password.
    I've seen this issue being fixed many times by reentering the network profile. You can also ask your ISP to do it for you. If reentering your current network key in a new wireless network profile doesnt work, ask your ISP to walk you through disabling the wireless key. If it connects after doing so, ask them to change the wireless key/password to a different set of numbers and reenter the profile again for the new password. It should work afterwards. Otherwise, you can leave the password disabled, if you live in a secure neighborhood. But still, it's better to be safe.
    I hope it works.
  • 10,515 Answers
I had the same problem (IP address already in use on the network - DHCP or static IPs made no difference - same error either way) with a SonicWall TZ 150 Wireless Standard router running Sonic OS Standard 3.1.3.0-6s firmware trying to connect a Toshiba laptop with Vista Home Basic. An IBM T-42 Laptop with Windows XP SP2 connected instantly as does every other PC in the house. I had seen a post recommending a firmware upgrade. We went to SonicWall's web site and after logging in to our existing support account (yes, you have to have your SonicWall registered to receive support!) we downloaded the firmware at version 3.1.5.0-2s and applied it. It took several minutes to upload the firmware to the router. Downloading and reading the release notes is key to getting the procedure to work. Make a backup of your current configuration first as recommended!
After rebooting the SonicWall router, everything came up and the Vista based laptop connected right away with no more errors.
If u believe that i have satisfactorily answer ur querry, u must select "Fixya" icon , so that i wld be paide for my services.
Take Care Bro.
Thnx.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Let us try forcing the new laptop to connect. Pls follow below procedures:
  • reconnect the Armstrong Zoom 500 through LAN cable to your desktop;
  • verify that you can connect to the Internet;
  • right click on the networking icon in the system tray (the double monitor);
  • click on Support tab;
  • click on Details button;
  • write down the listed information;
  • boot the new Dell Inspiron 1525;
  • goto Start, Control Panel, Network Connections, right click on the icon below LAN or High-Speed Internet and click on Properties;
  • in the "This connection uses..." scroll down till "Internet Protocol TCP/IP" is shown;
  • highlight it and click on the Properties button mid right;
  • enter the numbers you have copied from your desktop in exactly the same position/tags;
  • OK, OK, reboot.
  • pls try again moving the LAN cable to the laptop.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Sergeant:
    Champion:
  • 331 Answers
First did you try to use the complete modem (armstrong zoom 500) and see if then you are getting the internet.
if you are then either your Internal modem is not working. If it is a hardware proplem  i would suggest you to get  a replacement but there might be some problems witht the drivers. if you have the drivers for your laptop you could uninstall the drivers for the modem and reinstall them.
once you have done that you would have to once again  setup the connection (whatever you settings are  like the installation and then the username and password)
and see if it solves the problem
  • 488 Answers
Either the modem/ethernet driver is not installed or the connection is disabled.dou see two lights near the ethernet port?.use network settings and see the status of the connection..use enable this connection if its in disabled mode..u will need the IP address and other settings from the ISP if the router does not give IP address automatically..
as far as vista goes there is no problem as Mr ginko has said..
hope it helps!
    Genius:
  • 1,142 Answers
The best thing you can do is go into the device manager then select harware then go into the network adapter and you can remove the installed nic driver which might have got corrupted then you have to restart the computer, incase the device doesnt get recognised by the operating system then you have to install it from the dell drivers and utility cd which was provided to you with the computer you got, i have worked for dell for a couple of years you can get in touch with me for further instructions.
you need to provide me the service tag #
    President:
  • 1,263 Answers
Did you go into network connections? there you can hit the repair tab this should renew the IP address for you and at the same time recognize your lap top. also you should check that the proxy settings in your lap top match the settings in your desk top. keep me posted.......good luck
Posted on Sep 02, 2008
  • Dell Master
  • 19,396 Answers
If the laptop says limited connectivity, usually it is not getting the right IP from the modem, or the modem is not connecting to the Internet
  • 1 more comment
  • Ginko
    Ginko Sep 02, 2008
    First unplug modem and laptop from power, and remove laptop battery for 10 minutes.See if you still have limited connectivity.
    right IP from the modem, or the modem is not connecting to the Internet.
    The modem should have a led indicating internet connection, that must be lit.
    You must have done the modem setup entering your user and password details, plus some settings, I assume you did this at the phone with the tech support.
    If you did not do it you need to configure the modem.
    In this case unplug the modem, run the disk that came with the modem, or the downlowd you had from provider. Enter all details required.
    If it is none of the above, as laptop is new, with fresh Windows, the most likely is a faulty modem, get a replacement. A router is better, even if you have only one computer.
    Reinstall again modem software, after resetting modem, if it does not work modem may be faulty.
    If modem is ok check the ethernet cable, ensure is not sticking with power cables or power adapters. If you have another cable try a replacement.
    Also disable any firewall, like norton internet security, zone alarm etc. If it was the firewall you will need to configure it.
  • Ginko
    Ginko Sep 02, 2008
    The laptop is new, and this should not happen, but can also be the ethernet card in troubles. In this case go to control panel and get the installed devices list. Remove the ethernet card from system. Restart the system, on startup it will reinstall the card and reset all network settings.
  • Ginko
    Ginko Nov 23, 2008
    I gave you the solution, the laptop is new, and "Vista has problems on wireless" (as somebody told you) is rubbish, did you do what I told you?
    If you want to use wireless remember also that you will have to activate the wi fi card.
    Thanks.
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
Can not connect to wirless Dell 1525
Does it have awirless card or just an ethernet cable card?
Jul 28, 2009 | Dell Inspiron 1525 Notebook
Dell 1525 , wireless adapter
Go to http://www.halfdone.com and download unknown devices to get the correct wireless card info.
Apr 17, 2009 | Dell Ethernet Card Network Adapter
CANNOT INSTALL AUDIO DRIVER AFTER CHANGING VISTA TO XP IN DELL 1525 LAPTOP, PLEASE GIVE ME A SOLUTION
Here is a set of links to follow to get the appropriate drivers for XP for the 1525. You also might want to check Dell's site they have a list of drivers available for XP and the components.
http://support.euro.dell.com/support/topics/topic.aspx/emea/shared/support/reinstall/en/reinstall_center?~ck=ln&c=uk&l=en&lnki=0&s=gen
Follow this simple Installation step to downgrade Windows Vista to Windows XP.
a. You have to prepare SATA Driver on your USB Disk. You may get the Dell Inspiron 1525 SATA HERE
b. You have to prepare Dell Inspiron 1525 Wireless Card Driver as well known as Broadcom BCM 4311.
c. For Dell Inspiron 1525 Webcam you have to get Creative Labs Webcam that you may get it in the Windows Update Sites.
d. Get Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller drivers.
e.
Video Card Driver Intel GM965
Dell Application Software Quickset
Ricoh R5C833 Flash Drive controller Driver
Sound Audio Driver Dell Inspiron 1525 SIGMATEL STAC 92XX C-Major HD
Download Intel Chipset
Dell Inspiron 1525 Modem Conexant D330,HDA,MDC,v.92,
Touchpad
Notes: After installing windows XP, you have to prepare windows Downgrade XP patch for Dell Inspiron 1525 before installing Dell Wireless 355 Bluetooth Module and finish Dell Inspiron 1525 driver for Windows XP Installation. Enjoy Xp on your Dell Inspiron 1525 Notebooks.
Jan 29, 2009 | Dell Inspiron 1525 Notebook
Unable to connect to internet
Hi.
What do you mean by "reloading Windows"? Did you repair it? Maybe did reinstallation? If so, you may need to install drivers for your Ethernet adapter. You will need to specify Ethernet adapter manufacturer and model (if it is onboard adapter, then motherboard manufacturer and model), so I can provide you with the download link, in case you don't have the drivers.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525 wireless problem
Go to http://support.dell.com and under the drivers and downloads section, enter your Service Tag, and download and install the latest Wireless Card driver for your model. Update to latest BIOS version as well.
Jan 10, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell inspiron 1525
check your lan card maybe it is disable, try to enable it
Apr 12, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
346 people viewed this question
Alun Cox
