Savin CPL17 error message "486". I replaced the black PCU alreay, but the messgea still comes up.
  • koko79 Mar 20, 2009
    Savin CLP 18
    Same problem
I have a savin clp 17 and the error light has been on and it says color regis. The yellow is not mixing with the other colors. Please help.
Posted on Jul 30, 2010
If i take copies only black paper is coming and error shows as 302
You have some sort of a problem with the drum unit (PCU) in your copier. You don't specify a brand or model, but the code resembles that of a machine from the Ricoh brand line (including Lanier, Gestetner, and Savin) If this is the case, then this info pertains to your question, though may not be exact, as not all models within a brand range are laid out the same.
Below is what the service manual states, taken from a typical small to mid-sized unit:
SC302: Charge roller current leak
-> A charge roller current leak signal was detected.
Possible Problems:
• Charge roller damaged
• High voltage supply board defective
• PCU harness defective or disconnected
While this may not pertain to your model, I have seen this code occur if a securing screw for the cleaning blade in the PCU loosens and falls out of place. I've also seen on larger models (35 to 45 ppm) where the charge roller mounting arms are not making good contact with the metal tabs inside the PCU.
Jun 23, 2011 | Office Equipment & Supplies
Savin 9927dp photoconductor ?
THE MAINTENANCE PROMPT COULD BE TURNED OFF BUT THAT IS AGAINST THE MANUFACTUREERS RECOMENDATION. THE PCU
WOULD LAST A LITTLE LONGER BUT IT WILL START DUMPING TONER AND DEVELOPER IN TRAY1 IF IT ISNT ALREADY THAT JUST ADDS TO THE CLEANUP TIME AND COST THE PCU WAS DESIGNED TO MAKE 60,000 PAGES.
May 06, 2010 | Office Equipment & Supplies
I just replaced my black cartridge and my Aficio 41000 still says replace blank pcu - why?
The life counter of the black pcu has run out. It had nothing to do with replacing the toner. The replace pcu message comes on at around 50k on this model I think.
Apr 26, 2010 | Ricoh Aficio 1224C Black and White Copier
Savin 3510 add toner ,new toner in machine
THIS PROBLEM ALSO OCCUR IN RICOH AND GESTETNER/LANIER AS THEY SHARE SIMILAR OPERATING SYSTEM. WHAT YOU CAN DO IS TO CHECK THE TONE HOPPER OUTLET ,SOMETIMES IT IS BLOCKED BY MYLAR COVER WHEN YOU REPLACED THE NEW TONER..YOU JUST TURN THE TONER BOTTLE/TWIST A BIT AND YOU CAN SEE THE TONER WILL COME OUT FROM THE HOPPER OUTLET. IF NOT TRY TO FIX THE MYLAR COVER.
THE SECOND PROBLEM IS BLOCKED TONER INLET IN PCU .YOU HAVE TO TAKE OUT THE PCU & CHECKED THE TONER INLET,SOMETIMES IT IS BLOCKED BY SEAL OR THE JAMMED INLET CLOSURE MECHANISM AND IT CAN BE REPAIRED IF YOU HAD THE EXPERIENCESD SERVICING THE PCU. GOOG LUCK
Mar 15, 2010 | Savin Office Equipment & Supplies
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
173 people viewed this question
k24674
jasbo
jasbo
