Question about Toshiba NB205-N310/BN Netbook
Recently purchased an external dvd-writer for my nb205-n310/bn toshiba and i installed SOMETHING that apparently changed something in th MBR or boot.ini or registry or all of the above and more.... anyhoo... it can't find windows and just hangs after the bios splash screen with the cursor blinking... i'm NOT supe careless about what i dl/install.... either way i have multiple ways of booting into ubuntu live (via usb)/win 7 (install via usb AND dvd) and well i'm in the middle of getting a nb205 xp install/repair iso.... but i'm starting to get closer to solving this w/out it.... i think! any advise? or questions about what else i've got?
  • Toshiba Master
  • 787 Answers
Unplug the external dvd writer and don't plug it in untill after Windows boots.
Posted on Apr 05, 2017
SOURCE:
  • 1003 Answers
SOURCE: toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
AvioriX is right your operating system is gone.
if u dont have restore disk get a windows xp program disk from walmart or target or office supply store and load operating system from it.(this will only load windows xp.) but will bring computer back up
Posted on Jan 15, 2008
  • 366 Answers
SOURCE: Can't boot from USB (No CD Drive) for fresh install
Tricky one, ive you have a external usb cdrom drive , maybe, or if you can take hardrive out and set it up on another laptop install your xp and also place copy of all drivers required onto it, then put back into the toshiba., dont know what else could help you here. hope this helps in some way.
Posted on Dec 05, 2009
Testimonial: "Thanks, I am in between places for USB cd. I'll just wait for that and switch drives as a last resort for now. Thanks."
rcw1962
  • 2571 Answers
SOURCE: How to remove the motherboard on a Toshiba
The manual on the support page should tell you, but unless you have done this kind of thing before I would not try.
I have built a few pc's and repaired many pc's and laptops. and i would not want to try that.
Posted on Jul 10, 2010
nishantraj88
  • 98 Answers
SOURCE: Hello! I can not find where
SEE BESIDE MUTE BUTTON ,I DONT KNOW WHETHER IT IS OR NOT BUT IN MY NETBOOK OF HP IT IS THERE.
Posted on Sep 02, 2011
technolust
  • 340 Answers
SOURCE: need to update bios toshiba satellite c660,using ubuntu live dvd, will not boot hard drive, all normal recovery options used up
Hi There,
There are currently no easy ways to update a bios through linux at all - including live cd's. Your best bet is to make a bios update USB stick (or floppy depending on the age of the computer)
Here's a link to those instructions:
http://www.biosflash.com/e/bios-boot-usb-stick.htm
Alternatively, speaking from my own experience with a similar situation, you can take the hard drive out, use it in place of the usb stick, boot from it, update your bios, and go from there.
Posted on Jun 06, 2012
Testimonial: "Matt, exactly what I have been searching for, I am well advanced in years so will take me a while to configure this, I found the update OK but was a problem choosing the utility. WELL DONE & MANY THANKS Jim"
Nb205-n310/bn maxes at 800x600 screen resolution
Make sure you have the correct driver installed for the graphics. Right hand click on the desktop, select resolution and pick a size that fits.
Feb 12, 2014 | Toshiba NB205-N310/BN Netbook
Laptop Toshiba NB205. when i press the power button there is no display, i've tried removing the ram and display cable still no display when i fix it back, but other parts like the usb seems to be...
Check if it works with an external monitor. If it does your laptop screen may have a problem. However, if it does not work with the external monitor attached, your laptop may have a motherboard issue.
Feb 14, 2018 | Toshiba NB205-N310/BN Netbook
NB205 is stuck in hibernation mode. Tried taking out battery, pressing power button for 10 seconds, unplugging, hooking it up to external monitor, etc. If I can just get it to turn on 1 more time so I can...
Remove the battery and disconnect the power unit. Remove the hard drive and RAM.
Power the netbook up. It should complain that the RAM is too low and the drive is missing.
Power it down and replace the drive and RAM.
That will get it going again.
If it doesn't, you have a mother board fault and need specilised help.
Dec 16, 2010 | Toshiba NB205-N310/BN Netbook
Hello My nb205-n310 works perfectly until you put it into hibernation or turn it off. Then it won't boot up for a while, then, boots back up randomly to full usage. It is not battery or charger. short...
I'm assuming you have all the drivers installed and properly configured.
Yes, it appears that a part doesn't start up as it should. Run this program
http://www.cpuid.com/softwares/pc-wizard.html
and check the voltages, if one is low then the board is failing.
Jul 12, 2010 | Toshiba NB205-N310/BN Netbook
How to remove the motherboard on a Toshiba NB205-N310/BN netbook
Jul 10, 2010 | Toshiba NB205-N310/BN Netbook
Hooked up toshiba nb205 to toshiba lcd tv have audio no picture
you probably need intel graphic media software go to Cnet this will help with the video/picture
  • http://download.cnet.com/Intel-Graphics-Media-Accelerator-Driver/3000-2108_4-10300119.html
feel free to rate the help
Apr 03, 2010 | Toshiba NB205-N310/BN Netbook
Toshiba nb205 display problems
Search for the display drivers for your computer
Jan 04, 2010 | Toshiba NB205-N310/BN Netbook
My nb205 seems to spike to 100% cpu usage often...how do i fix that?
Start shutting off things that are running in the background. Type msconfig in the run or search window from start depending on XP or Vista. Go to the tab that says "startup" You can disable all if you wish the only program needing to run when windows starts is your virus protection. I do not know which one you are running but Avast will be AWIL Maffee is something like Mafee agent and Norton may say Symnatec or just Norton. The newer versions of Norton may not even have a start prompt you can stop. Anything Windows needs to boot with will auto select on after reboot.
Dec 30, 2009 | Toshiba NB205-N310/BN Netbook
Open Questions:
Toshiba NB205-N310/BN Netbook Logo
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
