Question about Sony Handycam DCR-SR300 Camcorder
SONY DCR-SR300 with CMOS viewfinder
When I take on "POWER":
viewfinder display not function
or picture starts blink and fades.
Camcorder took off himself and objective folds do not close.
This things appear or disappear when I displacement viewfinder in any directions.
  • 5 more comments
  • bugis_ly Nov 08, 2008
    my sony dcr sr-300 is 15 months, now it doesn't work ..
    first problem when its turn on the lcd views strips for minutes then working normal condition, but after a week the lcd is blank at all. now the power on is still working but the lcd blank ..dark!!!!
  • kroberts3 Jan 03, 2009
    When I turn on the handycam and open the viewfinder, it flickers and goes blank. Everything else seems to be OK.
  • Anonymous Feb 22, 2009
    i want to use my dcr-sr300 handycam like webcam on my pc....
    but i couldn`t ....If u can slove this pro plz contact me ....
  • spindoc Apr 13, 2009
    I just started having this problem with my Sony Handcam HDD DCR-SR300 about 1.5 years after purchase. Unfortunately, I can't find the warranty info, but I assume it was only for 1 year.
    The LCD screen started to flicker and then go dim.  Changing the angle of the screen helped avoid the issue for a couple of days, but now it is always dim and it shuts down randomly even there is plenty of battery power left.
    I'm going to have to take it in to get a quote on how much to fix it... unless you do it yourself types can give clear instructions. :-)
  • kiddopax1 May 11, 2010
    Can someone pls tell me the procedure for removing the display? I tried removing it but it got difficult after removing the 1 screw on the pivot and after prying the joint halves apart. There are 2 screws holding the display housing together but you can't get to them unless you have a specially designed screw driver, or if you manage to remove the display from the rest of the camcorder.
  • pilotrm May 11, 2010
    Can you please give me more info on this ribbon cable? Part number, where to get one, etc.
    I have the same problem and would love to fix it myself, i just don't know how or where to get a hold of one.
  • Anonymous Mar 26, 2014
    DCR-SR300 shuts off after 30 minutes
I suddenly had similar problems with my SR300. I replaced the flat ribbon cable (looks orange) between the body and the LCD display and camera works like new. The ribbon cable is subject to cracking the internal wires where it flexes when you open and close the LCD display. There was also a new part number for the cable so I suspect it is a known problem.
Posted on Dec 21, 2008
Same thing, does anyone know how to fix it now?
Posted on Jul 03, 2009
Sony DCR-SR300 touch screen did not respond
Quite possibly you have a bad connection in your LCD or bad LCD flex cable assy. This should be repaired by an experienced technician. www.austintelstarservices.com
Sep 03, 2010 | Sony Handycam DCR-SR300 Camcorder
Sony handycam dcr-sr300 the lcd screen is to dark to see
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Meggita
Jul 09, 2009 | Sony Handycam DCR-SR300 Camcorder
Display rolls on the handycam DCR-Sr300
Try resetting your Camcorder in the switch on mode.
If it does not help, switch the camcorder off, remove the battery, switch ON the cam for 15 sec and then switch it off and insert the battery again and try. This may help too.
Else the handycam needs a service.
Jan 03, 2009 | Sony Handycam DCR-SR300 Camcorder
Focus issues
My reply is bit technical. Your camera requires Flang-Back Adjustment.
Above said adjustment will set focus lenses in correct order / position to obtain crispy focus as it was before.
There are few special tools designed by Sony used in Flang-Back adjustment and only Sony Service Centers can perform such adjustments. Non-Sony repair shops do not have such things.
Just for reference, below view shows required tools for adjustments in this model.
Need further info let me know please.
Nov 27, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Sony handycam DCR-TRV25E viewfinder is blank
Correct, its CCD Imager failure case in your DCR-TRV25E camera.
Sony offers repair of your camera free of cost.
Click Sony Support UK to get details..
Good Luck.
Sep 27, 2008 | Sony Handycam DCR-TRV25E Mini DV Digital...
Sony DCR-SR200 screen slowly "scrolls" vertically like the V-Hold on an old television
After researching various flexible cable numbers from different posts, I found that the SR-200 uses a unique cable, FP-610, part number 187145711. This has been discontinued and replace with part number 187145721 (same cable also used in DCR-SR300).
If you are in doubt with your camera, just take it apart up to the point of seeing the ribbon cable. The part number is printed on the side.
I found two sources for this so far, www.nexttronics.com and https://servicesplus.us.sony.biz/sony-parts.aspx. Price ranged from $30 to $40 plus shipping.
Jul 21, 2008 | Sony Handycam DCR-SR200 Camcorder
Sony Handycam  DCR-SR300 Camcorder Logo
625 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
