Question about RIM BlackBerry 7290
Unable to sync a bluetooth headset
I have already once synced the headset to the blackberry 7290 and now i found the bluetooth icon missing from my 7290 and i cant seem to allow it to be paired with my headset. it doesnt help that my headset was washed recently but now have it charging it shows the light when charging.
    Novelist:
    Scholar:
  • 149 Answers
It appears your phone might not be syncing up with the headset since there might not be any signal at all. Do you have some one else's head set you might be able to borrow in order to test this possible problem? Maybe even stop by a mall phone booth to see if the blue tooth head set they have there for demo will sync up with your phone [besides you can always walk away after you test that and not buy anything just dont tell them before hand..].
See if this helps figure out the problem. It's one of the ways to test the problem and find a solution.
Let me know how it goes!
p.s. sorry it has taken so long for some one to get back to you. Let us know if you found a solution to this problem already in the mean time!
Posted on Oct 10, 2008
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
How do i sync my mad catz blue tooth headset to my ps3?
You'll need your controller, console, and headset to do this. Make sure your headset is off before you start, then follow these simple steps.
  1. Power on the PS3 console
  2. Within the "settings" menu, press X on "Accessory Settings"
  3. Press X on the icon labeled: "Register Bluetooth Device"
  4. Scroll down and press X on the icon labeled: "Register Headset/Microphone/Headphones"
  5. Prepare the headset to be paried by holding down the main buttong for 8 seconds.
  6. Once the LED flashes blue and red (indicatin the headset is ready to be paried), press X on "Start Scanning"
  7. Once Scan is complete, the PS3 will list all Bluetooth device visisble and within range.
  8. Locate your headset ID, most likely "8860" or something similar, and press X on it's icon.
  9. Enter 0000 (four zeros) as the Pass key and hit OK.
  10. Now enjoy your synced headset!
If any part of this confuses you, you can find the manual for your headset online here. You'll need a PDF reader to view the file. There are plenty of free ones on the web, but if you don't already have one, I'd recommend this one. It's free and simple.
Oct 05, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Blackberry 7290 battery icon with line hrough battery
This can indicate that the battery can no longer hold a sufficient charge for the device and may need to be replaced. To be sure, you can download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Jan 11, 2010 | RIM BlackBerry 7290
How do i sync it?
First start the bluetooth feature on your Blackberry.
Next, make sure the headset is off, then press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains
steadily lit. (The light will flash while you hold the Call button.)
Then go back to your Blackberry and have it search out the headset. When it finds it, connect.
Jan 10, 2010 | Motorola Mobility H505 BLUETOOTH HEADSET
I cant find the browser icon. iwant to know how to restore the browser icon of my phone blackberry 7290 rim so that i can surf the net using it
First, you will need to download and install the latest version of BlackBerry Desktop Manager software from https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Nov 20, 2009 | RIM BlackBerry 7290
RIM Blackberry 7290 have problems making calls, the phone will not ring and will drop and produce a call failed. then the signal meter will x out, also if connection is possible will not last more than 3...
This should help: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Oct 16, 2009 | RIM BlackBerry 7290
Sync to HS850 motorola - to blackberry
go to the sync option in your phone and turn bluetooth or headset on and then if its a bluetooth hold all the buttons on it downuntil it beeps or lights up
Sep 09, 2009 | Motorola Mobility HS850 Consumer Headset
T 305 passkey
Yes, I agree with joeypants77. Brilliant the passkey is 0000. I just bought a blackberry bold and it did not accept the Motorola T305 without a passkey and it workd:-)
Jan 26, 2008 | Motorola Mobility Bluetooth Hands-Free...
RIM BlackBerry 7290 Logo
237 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
