Question about Fuji FinePix S3000 Digital Camera
Hinge Pins The hings pins for the door to the memory card compartment have disappeared. The camera won't turn on unless the door is closed. I am using duck tape to hold the door in place. I tried Fujifilm and a local camera shop. Both said would cost $160.00 and take 6 weeks. Anyone have a helpful suggestion?
  • Clifford Wenger Nov 07, 2008
    The holidays are coming. I think it's time for a new camera.
Try a different store - its a common problem with this camera and larger stores might have the parts in stock it cost me $40 on the spot
Posted on Oct 28, 2008
  • 38 Answers
The camera itself is only worth 30 dollars now but if you look under the door there is a small black square if you wedge something in there like a piece of a paperclip or whatever you can defeat the "open door" sensor
or buy another fuji finepix s3000 (like a broken one from eBay) and pull the door off that one and put it on yours
Posted on Nov 06, 2008
How do I remove the front passenger door on a Citroen c5
Examine the hinges. They may be bolted from the outside at the door side. Another option is remove the 'drop pins' holding the two half's of the hinge together. Some hinge pins are only held in with a spring clip. Your only other option is to remove the front wing and unbolt the door with the hinges still on.
To remove the pins-
Proceed as follows...
Support the weight of open the door.
Tap the spring clip sideways off the thin end of the pins,
(located top of the top hinge and bottom of the bottom hinge).
Tap the bottom pin upwards then the top hinge downwards.
You might need to wriggle the door to get them to move.
Put the bottom pin in first as it 'drops' in and the upper pin pushes up into position.
Again, you will have to wriggle the door and GENTLY tap the pins into place.
Swopping the the pins makes it easier to line up the new door as it closes.
Dec 26, 2017 | Citroen Cars & Trucks
Whirlpool Supercapacity 465 Oven (RF396 LXE2) Door Problem
These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
Feb 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Why is driver door not closing properly?
hinge pins are probably badly worn, which will soon damage latch if not already. links to videos of different hinges pin install below
press the helpful button
Door Hinge Pin
Jan 31, 2016 | 2003 Suzuki Grand Vitara
Hmmm... If like other cars, you would normally adjust the striker post on the B-pillar.
Unless the hinge pins are worn, in which case the door would drop, and need lifting as you closed it, to allow the lock to align. The pins are usually replacable.
Nov 09, 2013 | 1997 Lincoln Town Car
How do I replace the long screw that holds the door up on the door hinges,on a '97 gmc Sonoma?
I have done a 100 of these.
The hardest part is going to be to reinstall the spring on the lower hinge arm. this is not a screw but rather a pin.
There are two hinges that hold the door to body.
when the upper and lower pins are removed the door will come away from body, it is important that before you remove the pins you take a look at the hinges.
Pay close att. to the way the hinges sit inside each other and the way the pins go in. see if they go from top to bottom or from bottom to top. also note where the copper bushings sit in hinges. each hinge has one pin and two copper bushings top go into hinge.
Over time the pins and bushings wear out ,making door hard to open and close. When the pins and bushings get so bad that the bushing is worn out and then the pins are now wearing into the hinge hole itself then this get tricky. if hinge hole is egg shaped the new bushings will not last. the door will hang again in a few weeks. this is where is get costly, the hinges now need replacing. i have gotten good at welding the holes and filing them back to shape but this takes skill or hole will be wrong and bushing will not fit or line up.
Here is a youtube video to help you.
Take note. put jack stands under door with cloth to avoid scratching door.this is to hold door when pins are removed. have somone help you, they will hold door on stands. the wires will still run through door, pull door away from body a little to allow room to work.remove the spring, it will fall out as you remove pins, remove old bushings, clean hinge area and holes,next install new bushings, apply lube to holes for pins and on bushings, slide door back on frame hinges and install pins, next slide lock washers on pins to hold pins. last is the spring. you will need a spring tool, you may rent one at auto parts store. hope this helps good day.
Feb 26, 2012 | 1997 GMC Sonoma
The interior light stays on unless I slam the driver door one or two times?
Check for wear on door hinge pins.
The door may be sagging.
May need to repalce the door hinge pins
Jun 26, 2011 | 1997 Chevrolet Blazer
Driver side door does not close. Latch broken and door sits down below catch on body of car.
may need new hinges on door and body of vehicle, if so it is about 600 -700 to replace , may be able to get new bushing and pins , without replacing hinges
Sep 09, 2010 | 1998 GMC Jimmy
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
Position the door with the hinge hanger slots
almost parallel to the front frame.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Door sag
Hello, you need to replace the hinge pins and bushings. Just take a hammer and knock the hinge pins out and put the new pins with bushings in the hole and tap it into place. Some vehicles have a locking ring on the bottom of the hinge pin just knock it off with your hammer and a screwdriver. They don't have to be replaced but, if you want the dealer sells those too. Good luck and any questions please ask.
Jan 23, 2009 | 1999 Chevrolet Tahoe
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Fuji FinePix S3000 Digital Camera Logo
73 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
