Question about Dryers
220 volt dryer outlet is only testing at 110 volts what could be the problem?
  • 1 more comment
  • leatherne633 Sep 03, 2008
    pulled breaker and black fell right out was not in **** it was jamed behind it in between bottom of bracket and breaker body...lol
  • Anonymous Jan 26, 2009
    my dryer is doing the same thing running but no heat. So you say it probably is not the breaker? Would it be the 220 outlet? Or a new 220 plug? Thank you so much
  • Anonymous Mar 13, 2014
    was erroneously connected to 220 volt current outlet socket
  • 1,543 Answers
If your home has fuses, one of the 30 amp fuses may be blown. If breakers, not as likely you have a bad breaker, but possible. Check voltage at main electrical distribution pannel. Look for loose connections.
Posted on Sep 02, 2008
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I need to make a 110 volt leg from my existing 220 volt dryer outlet.
Dear Sir:
See the diagram attached, you must USE VOM carefully for to measure the 110VCA. Disconnect the power C.BREAKER from your house. Before to make any job.
God bless you
May 23, 2012 | Dryers
My 70 series dryer the heating element is not working. I checked the heating coil for continuity and it is holding 12 ohms, the fuse has continuity and it has power. Flipped the breaker to se If that was...
your voltage is not right as it should be 220 volts, check the outlet to see if you have 220 if you do then its the cord, if not then it is either the outlet or the breaker-panel, to check panel remove panel and test both legs of the breaker you should have 220 if not then replace the 30 amp breaker. Tim
http://www.ehow.com/how_7403710_replace-kenmore-70-series-dryer.html
May 27, 2011 | Kenmore Dryers
I have a 220 volt crape maker from France. Can i change the cord on it to be used in a 110 outlet? Will it still heat up enough with 110 volts?
Unfortunately, it will probably not heat up enough on 110 volts. You could change the male plug on the end of the cord to fit your 220 volt air conditioner or cloths dryer female plug.
Dec 03, 2010 | Kitchen Appliances - Others
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
A diagram of how to wire a 220 volt outlet from two 110 volt outlets.
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
Sep 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer
    You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
291 people viewed this question
Top Dryers Experts
