Question about RCA HD52W59 HDTV Projection Television
Fl231 fuse compatibility
RCA HD52W59 w/ ITC222 Conv board
I've been reading all of the posts about convergence and have the same problem as a lot of other people on here. The convergence is all out of wack and the convergence option is missing from the menu. I pulled fl231 and tested it. It is bad.
The only place where I could find the fl231 fuse was They didn't have any specific information about the fuse on the site. All it said was that it was the fl231 replacement fuse. I ordered one and it arrived today. The numbers on the fuse don't match the ones on the blown one. They are both 400ma 125v, but the new one is f400ma and the old one is t400ma. I searched for f400ma on google and it said that it was a quick blow fuse. If I'm not mistaken the t400ma is a slow-blow.
Is this the correct fuse for my set?
  • mikenbonn Oct 12, 2008
    Well, I've got the same problem as well but I'm unable to locat the fl231 fuse......The model number of my rca tv is P60812BL and I have absolutely lost my mind trying to find that darn fuse...... PLEASE anyone help me locate this fuse.....TY in advance...
  • RCA Master
  • 8,617 Answers
Yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Posted on Sep 04, 2008
If you replace just the fl231 it will blow again. You will need to replace the FL231,DL231 and CP230. You can get the parts at the following link with free instructions with pictures total cost is about 26.00. Its listed under the RCA repair kits as the ITC222 & ITC222A convergence option missing repair kit. Its available at
Dec 29, 2011 | RCA HD52W59 HDTV Projection Television
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
Nov 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 TV Convergence problem
it is not to bad if Convergence are not moveing by the flyback
you see 3 fuse look like litte box in a row hit
tham, if the led in front of tv blink more then one your fly back is bad to,as you look at the board look at the cap.s on your board you see a cap,it a bout to blow. hope this help you out.
Aug 25, 2009 | RCA HD52W59 HDTV Projection Television
Convex picture - can I fix it myself
sounds like the convergance ic are bad
Sep 29, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA HD52W59 Convergence issues after some repairs.
Hello rmolen,
This is an indication that the convergence amps are drawing too much current which has an effect on the power supply and thus killing your sound by removing or lowering the voltage supplied to that stage, finally this results in the blowing of the fuse. I would suggest that you change the convergence amplifiers and the biasing resistors (All of them) and then see if this corrects your problem (I believe it will). Also get a schematic of the TV and try to find out how the power supply relates the sound module and the convergence module, they might share a common power bus, or the voltage regulator for the sound also feeds the convergence board.
I hope this helps,
Thank you,
Jul 08, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
1,497 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
