Hi The F30 error code means when the
dispenser motor cannot be driven to its proper position. It could be a
mechanical failure in the linkage between the dispenser motor and the top of
the dispenser. Also loose wire connection between the machine control board and
the dispenser motor or a failed dispenser motor can cause this error. Please check the link for the list of
codes and the easy fix to it.Hope it will help you. Please get back to us if you have
further query else please accept the suggestion.
Thank you for contacting fixya.com
Hello tcavness609 - Are you certain the error code is F30? This manufacturer does not have a F30 error code for any washer. However, there is an error code F31 that indicates that the pressure senor is not communicating with the main control board. A professional will need to inspect the wiring between both parts and depending on the diagnoses either part will need replacing.
