Question about Canon EOS-20D Digital Camera with 17-85mm Lens
Focusing Problems I just bought the Canon 20d. I shot a wedding with it two weeks ago, and really liked how it performed in low light. However, I noticed a lot of my photos from the low lit reception came back out of focus. (The outdoor ceremony shots were fine). I noticed 3 issues with the images: 1-The main subject, which often was dead center and took up 1/2 to 2/3 of the frame, was often NOT in focus. Rather, the camera selected some point way off to one side or off in the distance somewhere to focus on. 2-Some photos had the subject in focus and the background soft. This is fine, however when i looked where the focusing point was in the Canon Utility program, it said that the focusing point it chose was actually NOT the in-focus subject, rather something else that was not in focus. 3-Some images came back perfect focus with deep DOF, but when I looked where the AF point was, there were NONE lit up. I was using P mode, 400 ISO, evaluative metering, an external 580 flash, single frame shooting, and One Shot mode. I also used both a 17-35mm 2.8 and a 28-70mm 2.8 Canon lenses. The reception hall was fairly low light, and sometimes the subject was moving, and sometimes it was stationary. Any ideas why my focusing seems to be all over the map? Thanks!
    Sergeant:
  • 255 Answers
* Get AF off the shutter release and onto the * button using the custom function. * Use the center focus point only. Force yourself to pick what you want in focus, AF, then recompose and shoot, a habit far more effective than computer driven multiple AF points for just about everything. * AF performance degrades in low light no matter what camera you own. This is life. At least if you control the when/where of AF, you can try and choose high contrast points in the scene to focus on, points that will help mitigate the low light. * Not sure if this applies to you, but it does apply to many a pixel peeper...if something prints sharp at 8x10 or 11x14 then AF has succeeded even if it's a little off at 100% in Photoshop. AF is not perfect and the tolerances are not necessarily up to producing 40" enlargements, which is what 100% in Photoshop is. Having said that, in good lighting with good target contrast the AF on your 20D often will nail focus so perfectly that it will hold up even at 40".
Posted on Sep 14, 2005
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
Grainy, Spot Filled Images when using Manual Modes Only
It sounds like the aperture is getting set very high. If the aperture is a high number, the lens opening is very small which lets less light in and would cause a dark image. This would also show any dust that is in or on the lens or image sensor. The dust doesn't usually show on apertures with a larger opening (smaller number). Make sure your aperture is being set to a reasonable number, probably no higher than 8 or so.
Oct 29, 2008 | Canon EOS-20D Body only Digital Camera
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Ixus 750 Blurred photos shot at a distance greater than a meter.
Check to see that the camera is not in "macro" mode, which would only allow focusing at a close range, but not allow focusing at beyond about 2 meters (look for the "flower" symbol to tell you that macro is activated). Could also be an out of adjustment lens, due to impact or force. Also check to make sure it's not as simple as a dirty lens. Digital cameras are more succeptable to blurry pictures from a smudged lens than film cameras were. Of course, that wouldn't explain why close shots are OK but distant ones aren't. Probably the first two suggestions.
Oct 06, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a Canon 20D camera that I use with two lenses. The lens that I have most of my problems with is the 28-70 f2.8 red ring lens. When focusing It always seems to focus on what is behind the subject. No...
This is quite a well known problem called 'back focusing' there is little that can really be done about it, except if the camera is under warrnty you can send it in and they will do some laser alignment that fixes the problem, it would be worth a call to canon and getting a price quote on a service. Also it seems to be worse with some particuar lenses,
Cheers
Emmanuel
Sep 12, 2008 | Canon Cameras
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Sharpness problem
That should be a very sharp lens, only thing I can think of is that you have a bad copy. It can be sent into Canon where they will fix it.
First, I would try giving it a full cleaning, and taking shots in good light on a tripod at 17-80mm, just to make sure its really the lens
Dec 15, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon 20d error 99
does the camera work OK with other lens? If yes then Lens is the patient - only 4 moths old -send it back
Sep 12, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
"busy" Error
check your firmware version and update if necessary. Usually you get the "busy" message when your camera is writing to the card and it's possible the card isn't quite right - a format should fix it. Alternatately you might try a different CF card to see if the problem goes away. Good luck!
Sep 14, 2005 | Canon EOS-20D Digital Camera
Canon EOS-20D Digital Camera with 17-85mm Lens Logo
119 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
