Question about Kenmore Dryers
No power to burner ignitor - Kenmore Dryers
    Genius:
  • 1,028 Answers
Ckd for 110 volts to valve connection.. or just try jumping out flame sensor temporaly it mounts on side of burner 2 wires
Posted on Sep 02, 2008
Whirlpool clean touch dryer is not heating up. The drum turns, the filter is clean and there is suction at the filter. the dryer is running cold on all temp settings and dryer settings. The gas line has...
If you are handy you can do it yourself. There should be an ignitor near the burner. It gets red hot when you turn on the dryer. There is a bi-metal switch "looking" at the ignitor, which will cut off the ignition and at the same time energize the gas valve(s). If this is not happening, either there is no power going to the burner assembly, or the ignitor is broke (split).
May 08, 2011 | Dryers
Trying to locate the ignitor on a bosch nexxt dryer..........looking through the round hole on the bottom left.....haven't found it yet. any help? tx
Welcome to FixYa.
The ignitor and burner assembly/burner tube are accessible from the rear and the rear panel must be removed.
i.e.
Once that has been removed, you'll need to remove the rear drum support & drum.
i.e.
Then you can pull the drum assembly out...Now you should see the motor and burner components. The ignitor is partially hidden via the burner tube, but is pointed out in the image below.
Hope that helps you identify and access the ignitor for your Bosch WTMC dryer, good luck.
Regards,
Macmarkus :)
Feb 17, 2011 | Bosch Nexxt WTMC3521UC Gas Dryer
Our dryer stopped blowing out warm or hot air. All the buttons still work and cool air still comes. Any suggestions?
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
  • Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome.
  • When the burner is operating properly, the flame should be clean and blue.
  • If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
  • If the ignitor doesn’t glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor.
Good Luck and have a nice day.
Jun 03, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore propane dryer 70 series does not lite
Assuming the gas is on. The most likely problem is a bad ignitor. Remove the bottom front panel(pop 2 clips at the top of lower panel with a flat screwdriver) and turn the dryer on Look for the ignitor to glow. If the ignitor does not glow test leads to ignitor for power if you have power replace it. If the ignitor glows then you are not getting gas check to make sure the gas supply is on.
I hope this helps if you need further assistance please let me know.
Apr 14, 2010 | Kenmore Dryers
It's run but there's no heat
The gas dryer has a spark ignitor that starts the burner to heat up. Upon switching on the dryer you should hear the ignitor clicking to light the burner. If you do not hear the clicking noise the ignitor needs to ne replaced
Mar 27, 2010 | Whirlpool LGR5636L Gas Dryer
This is the closest model # I could find but I have a gas dryer model TGDX640EQO and it doesn't heat up but does tumble. My husband thinks it is the ignitor, how would you determine that?
First clean all the dust and lint from around the burner and its components, including the sensor which 'tells' the dryer that the ignitor is on or the burner is lit.
There are two different types of ignitors. The most common glows a bright red to light the burner. The other gives off a series of sparks.
In either case, a visual examination should tell you whether the ignitor is working. Before you start the dryer, remove the burner access panel. Have someone start the dryer while you look into the burner unit to see if you see the 'glow plug' or the 'sparker' trying to light the burner. If not, the ignitor is probably bad.
If the ignitor is not the problem, look for dirty or defective sensors that will keep the burner from coming on. If these sensors do not sense the light given off by the ignitor, for safety reasons the burner will not come on.
Hope this was helpful.
Oct 10, 2009 | Estate TGDX640JQ Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Flame shuts down after 5-8 minutes
AFTER THE BURNER SHUTS DOWN THE 1ST TIME IT SHOULD COME BACK ON WITHIN 1 TO 3 MINUTES. WHEN THE BURNER TRIES TO COME BACK ON YOU'LL HEAR A CLICK AND THE GLOW OF THE IGNITOR SHOULD BE VISIBLE. AFTER 30 TO 60 SECONDS IGNITOR SHOULD FADE AND THE BURNER SHOULD FIRE. IF IGNITOR FADES AND BURNER DOES NOT FIRE YOU WILL NEED TO REPLACE BURNER COILS #279834. IF IGNITOR DOES NOT COME ON YOU WILL HAVE A T STAT OR SENSOR ISSUE. SOUNDS LIKE COILS TO ME. HOPE THIS HELPS PLEASE FEEL FREE TO CONTAT ME HUBAPPLIANCE@COMCAST.NET. PLEASE RATE MY RESPONSE.
Jun 23, 2009 | Dryers
Whirlpool LP dryer will not light. model LGR7646EQ2.
the ceramic ignitor probably is broke. turnoff power and gas, then remove burner assembly ther are two screws holding it in. also loosen gas connecter .pull burner out an visibly check igniter you most likely will see the ceramic coil broken remove it and bring it and model # to a part house then reassemble burner
Jan 26, 2009 | Dryers
Will not heat, ignitor and thermal switch on burner ok, whirlpool dryer
replace coils on burner assembly ..the 2 black things with wires ..if ignitor is glowing but burner not firing
Aug 25, 2008 | Dryers
Dryers Logo
66 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
