Question about HP Computers & Internet
When opening my hp laptop I get a adobe reader error message. Says it can not open file because it is not supported or is damaged. Then when I click on anything it does the same thing. Any help would be great.
    Scholar:
  • 152 Answers
Your computer most likely has a virus (probably a worm). Try different antivirus solutions (start with free versions) because some antivirus programs report that the system is free of viruses when in fact there still is. Install and run the antivirus only one at a time. Having two or more antiviruses can cause some problems.
Posted on Sep 02, 2008
Pdf file cannot open
What version of Reader are you using? Some newer .pdf files ure using formatting codes that older versions of Reader cannot decipher and thus fail to open. Older files will still read regardless of the version of reader. Ensure you have the most recent version of Reader and try again.
Mar 03, 2015 | Adobe Systems Adobe Reader
Adobe acrobat reader
Try to download the file again or if it was sent to you via email, have the sender verify they can open the file & resend it. There are tools you can use to try to fix problems in PDF files, but they should be used as a last resort since they cannot fix all errors without data loss or corruption.
Sep 03, 2014 | Computers & Internet
Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly...
Help with PDF Documents Some documents on Maine.gov are provided in PDF format. In order to view or print PDF documents, you need the free Adobe Reader. Generally, you will find an alternative format is also provided for the document, such as Microsoft Word, HTML, or plain text. If you cannot access a document in PDF format and there is no alternative version, please contact the agency or contact the Maine.gov webmaster for assistance.
Adobe PDF-to-HTML Online Conversion Tool
We've provided solutions for some common PDF issues below.
General Tips: Problem 1: Blank Page in Browser You have selected to download a file and you receive a blank page with a "Done" message at the bottom of the browser. This may be because you do not have enough space in your temporary internet file folder to complete the download.
Solution: Internet Explorer: Tools> Internet Options> Temporary Internet Files> select Delete Files
Netscape: Edit> Preferences> Under Category on the left Advanced> Cache> click Clear Memory Cache
Problem 2: Blank Page "%PDF" You received an error message containing "% PDF" or you have received a blank page while trying to download. This is due to a problem with your web browser not opening .pdf documents correctly.
Solution: Adobe Acrobat Reader 5.0: Edit> Preferences> General> Options> Web Browser Options> make sure the Display PDF in Browser box is not checked.
Adobe Acrobat Reader 6.0 and newer: Edit > Preferences > Internet > make sure the Display PDF in Browser box is not checked.
Problem 3: "Error Locating Object Handler" You receive an error message that says "Error Locating Object Handler" while trying to download a document. This is because there is a dependency with a plug-in for Adobe Acrobat while using Internet Explorer.
Solution: Please go to the following website for detailed instructions: http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262213
Problem 4: Unable to Print You have successfully downloaded the pdf, can view it on your computer screen but are unable to print. This is due to a post script error with your printer.
Solution: In any Acrobat Reader program: File > Print > check the Print As Image box > OK
Problem 5: "Adobe Reader could not open file" You received the error message "Adobe Reader could not open 'filename.pdf'" because it is either not a supported file type or because the file has been corrupted (for example, it was sent as an email attachment and wasn't correctly decoded).
Solution: Adobe Acrobat Reader 6.0: Edit> Preferences> Internet> make sure the Display PDF in Browser box is not checked.
Aug 26, 2010 | Computers & Internet
Cant open pdf
Make sure only adobe 9 is the only version of adobe reader you have installed on that computer. Then go to where your PDF file is and right click on it with the mouse and go into properties.
In the general tab where it says type of file it will show you what program is opening up the PDF file. Click on the change button and where it says recommended programs see if Adobe reader is there, if its not then down below where it says other programs click on the down arrow and see if adobe reader shows up there. If it shows up in either section then choose it, then click on apply, and then click on okay.
Now if for some reason adobe reader doesn't show up in either section, then you'll need to browse for it. It normally installs itself in the program files folder, then double-click on it and go into the adobe folder, Adobe 9.0 and then the reader folder. The name of the reader program looks something like acrord32 and it will say application to the right of it. At that point choose it and apply the changes so it opens up with Adobe reader.
This should cover everything, if your still having problems, let me know and I'll help you out further.
May 22, 2010 | Dell Dimension 4600 PC Desktop
I keep getting messages ..could not find acrobat External windows handler; . brand is e machines ..error messages,,
Hi Kate1958. I found this for you. Do one or more of the following solutions:
Solution 1: Remove all versions of Acrobat or Reader, and then reinstall one version.
If multiple versions of Acrobat or Reader are installed on the system, remove all versions and then install only one version. See the documentation included with Windows for information about removing programs.
Note: If you need to have multiple versions of an Acrobat product installed, remove all versions and then reinstall them starting with the earliest, installing the latest version last.
Solution 2: Start Acrobat or Reader, and then open the PDF file in the web browser.
If an error occurs when you try to start Acrobat or Reader, refer to Related Documents below, or search the Adobe Support Knowledgebase:
-- If you use Acrobat, go to www.adobe.com/support/products/acrobat.html .
-- If you use Reader, go to www.adobe.com/support/products/acrreader.html .
Solution 3: Make sure that the External Window Handler file (ewh32.api) is in the Plug-ins folder.
If this file is missing, reinstall Acrobat or Adobe Reader.
The default location of the Plug-ins folder is:
-- For Acrobat: Program FilesAdobeAcrobat [version]Acrobat
-- For Reader: Program FilesAdobeAcrobat [version]Reader
Solution 4: Disable Web Browser Integration.
Disable Web Browser Integration so that PDF files open directly in Acrobat or Reader instead of in the web browser.
To disable Web Browser Integration in Acrobat 6.0.x -7.0.x or Reader 6.0.x -7.0.x:
1. Open Acrobat or Reader.
2. Choose Edit > Preferences > Internet.
3. Deselect Display PDF in Browser.
4. Click OK.
To disable Web Browser Integration in Acrobat 5.x or Acrobat Reader 5.x:
1. Open Acrobat or Acrobat Reader.
2. Choose Edit > Preferences > General.
3. Click Options in the list in the Preferences dialog box.
4. Deselect Display PDF in Browser.
5. Click OK.
To disable Web Browser Integration in Acrobat 4.x or Acrobat Reader 4.x:
2. Choose File > Preferences > General.
3. Deselect Web Browser Integration in the General Preferences dialog box.
4. Click OK.
I hope this helps. Please dont forget to rate and provide positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Computers & Internet
There was error in opening the document, the file has damaged and could not be repaired... This error i got while opening my pdf document, can you please help me in resolving it as that document is very...
uninstall Adobe Reader and reinstall it or download it from www.filehippo.com
also checked for the default file extension ...
change .PDF to open with ADOBE reader always ..
after u install the adobe reader and complete teh setup
rt click on the file that you want to open click on open with
select ADOBE reader as default format ..apply.... ok...this will work
Mar 19, 2010 | ScanSoft PDF Converter Professional...
Adobe reader error message
It is possible that somewhere along the line adobe reader became conflicted with an update from something else ect.
First thing you should try is uninstalling adobe reader completely in add/remove programs. Then Install the latest version of adobe reader.
This should put an end to the error messages and restore functionality to normal.
Post back if you need any further help.Thank you for choosing Fixya!
May 27, 2009 | Adobe Acrobat 7.0 for PC
Is there any way to open an Acrobat 9 file with Adobe Reader 5?
Download the Adobe Reader 9 software. It's free from Adobe.
Mar 01, 2009 | Adobe Acrobat 6.0 for PC
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Adobe Reader
It could be that you have an older version of Adobe Reader. You can download the latest version: CLICK HERE.
Jun 05, 2008 | Adobe Acrobat 6.0 for PC
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
