Cohassetmusi
hello
F1 means the flood sensor senses water at base of machine at PC board.
You
need to take out bottom drawer and check for water puddle under where
the drawer was.If there is water you can get the machine going again by
comletely drying it out(F1WILL CLEAR),but it still means you have a
leak.With bottom drawer out you can really see whats going on.Once F1 is
clear you can actually run upper drawer and see if it leaks.Most likely
culprit are the lid actuators.Replace
all 4 . It'll run like new.Don't overload drawer .That can cause lid
leak too.Also the PC board may be damaged and may start to go crazy
giving fake F1 codes.$80 easy fix.
good luck
