Question about Panasonic KX-FL501 Plain Paper Laser Fax
Fax problem How can I check the rollers easily for obstruction?
  • drpeake Sep 02, 2008
    cleaned rollers still catching and saying paper jammed.
    one of the white rollers from the front is broken off.
    Is that the problem.
    The little white ones on the top of the door right directly avove the main black exit rollers.
    Genius:
  • 1,847 Answers
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Error 5100 for canon mp258
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt. There may be even some paper caught underneath the rollers. Jiggle around to see if you can jostle anything free. Check VERY thoroughly.
May 17, 2011 | Office Equipment & Supplies
The paper alwayes jamming
If paper is consistently jamming, there are two usual suspects: worn feed rollers or a physical obstruction. If the paper comes out with a crease or dog-eared corners, you most likely have some sort of debris blocking the paper path. However, if the paper doesn't have any creases or bends, then the feed rollers have most likely worn out or need to be cleaned. For obstructions, I would suggest manually feeding a thick piece of card stock through the machine in hopes of clearing out any debris or stuck paper bits.
-David.
Nov 02, 2010 | Office Equipment & Supplies
Trying to send fax & rollers will not pick up paper. Can we buy replacement rollers & are they easily fitted?
try cleaning the rollers with benzine or metholated spirits that part of the machine can be partaily opend by lifting it up
Oct 29, 2009 | Brother FAX-8360P Plain Paper Laser
Try to send fax=put in paper and it does not go
Open top cover look for an obstruction. Clean roller and pad w/alcohol.
Look for a switch actuator being stuck in the down position.
Sep 11, 2008 | Brother Office Equipment & Supplies
I have a Panasonic Telephone Answering System with Facsimile Model no. KX F250. The rolled paper won't advance, even though it sounds as if it is. I have checked for papers jams, paper scraps between...
THere must be a rolled paper in the roller exit...
try to remove is there is such...
roller exit is located on the cover...
it is a long black roller about 8 inches long.
its color is black...
is you see white long roller on the cover, that is the problem....
remove that rolled paper
HOPE it helps.
GOD BLESS YOU.
JOHN 3:16
Aug 14, 2008 | Panasonic Office Equipment & Supplies
Problem with page cut-off
See pages 92 of the manual to "rotate the white roller"
The procedure rotates the roller a quarter turn each time.
You might have to repeat it a few times in order for thit to be set at the right position.
I tested mine using the copy function as well as a TEST FAX to a another fax machine.
Good luck!!
May 29, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Unable to clear "Check Paper"on brother Intellifax 1270
Your "Check Paper" problem is then most likely caused by faulty sensors or a broken roller. Using the faulty sensors, you can use the manual that came with the printer in order to locate and clean the sensors. If your sensors are not the problem, and the paper can be easily pulled out each time you try to print, then you have a broken roller. The replacement rollers cost about $120.
Here is my reference: https://secure.fixyourownprinter.com/forums/laser/3576#1
If you have any more questions, please don't hesitate to ask.
Thank you, and good luck1
Mar 13, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Check Paper
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
Panasonic KX-FL501 Plain Paper Laser Fax Logo
27 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
