Just received a new Axim due to the bad D-Pad (Received it in one day - way to go Dell!!). My question is if I make a back up of my present Axim with Dell's included Back Up Program or even with Pocket Backup by Sprite Software, can I restore it to the new Axim? Thanks for any thoughts.
Make a backup of your existing Axim using ActiveSync on the desktop. It's slow but reliable. Backups created by Dell's Data Backup utility have failed to restore as reported by a number of people in this forum. Remove your old Axim from the cradle and put the new one in. When the Partnership Wizard prompts you to create a new partnership, click Cancel. You will now be connected via a Guest Partnership. Use ActiveSync to restore. When the restore completes, you should get prompted to remove your Ax from the cradle and soft reset. When you put it back in the cradle, your Ax should be recognized under the existing partnership. Do not connect your old Axim for syncing after a successful restore to your new one.
The backup utility included on your Dell Handheld will backup your data to a storage card. You can restore on your replacement handheld from that storage card.
From your Host PC, you can go to Tools | Backup/Restore and do a backup to the Host PC, and you can then restore after syncing the replacement handheld for the first time.
My Axim X51 will not allow me to download a library program that meets the specs. It(the...
(More)
My Axim X51 will not allow me to download a library program that meets the specs. It(the axim)message says its not a program made for PDa but it is. Whats up with this?
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white...
(More)
What do i do if my palm freezes? I tried to go into notepad and now can't get past a blank white screen.
i can't stard my pocket PC .when I press the boutton
power this message s' post on L screen...
(More)
power this message s' post on L screen (maitenez the stylet pressed on
the target with each position on screen.la target will continue to
move jusqu' has what l' alignment is correct) .i make all its stages
but it does not start, so help
me and thank you .
