Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Belkin g + mimo and xbox 360
I have a pc using ethernet and laptop using wireless connected to belkin and they both work fine, I use wep security on belkin. My son has an xbox 360 we want to connect it using wireless. If i remove security on belkin the xbox connects fine, if i then put security back on, the xbox gets disconnected. With security on the xbox asks me for wep key, i enter the same as on the belkin, it keeps saying invalid wep. Ive checked connection setting and ip address etc and they all match. Im not a wiz at this kind of stuff, i just cant see where im going wrong. Please help
  • suecmm Sep 03, 2008
    Yes. Tried all that, the wep key is identical on both machines. Dont know if it makes any difference but the pc the belkin is connected to is running on vista. Thanx
  • Anonymous Oct 01, 2008
    ican run desk top and laptop thro router ok without encryption when Itry to encrypt i get to enter a passprase and nothing happens and i must go back to disable security any help?
I have the same problem. The 360 will not connect to some routers with WEP enable i don't understand why
Posted on Sep 20, 2008
    President:
  • 2,961 Answers
Are you typing the correct upper or lower case and not confusing zeros with the letter 'O'
Posted on Sep 02, 2008
  • andrew pester
    andrew pester Sep 03, 2008
    No that shouldn't make a difference, it's the router thats got the security have you run the wireless network setup again in the xbox as sometimes it just won't connect, assuming you have got DHCP enabled in the router and performed a restart on the router (not Reset) and it may allow the xbox to connect.
I have a belkin wireless g plus mimo router and im trying to hook up my xbox 360 wireless and its asking for a wep key or wpa pass phrase how do i find that out?
You can find the wireless password also called wep key or wpa pass phrase through the set-up page of the router. If you don't know how to access it, follow the instruction in How to Access the Router's Setup Page (just click it.)
Nov 09, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin G+ MIMO router kicks my 360 (wired directly to router) and my laptop (of course, wireless) off of the network at random times, its incredibly bothersome and i'd like it solved
that happens alot when one or more device (for instance, the xbox 360 and a cpu) are trying to use the same ip address make sure you have the xbox 360 and all other devices (cpu's/printers) that are connected to the router set to aquire ip address automatically
Feb 03, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
WEP to WPA
Ok, access your routers web management page.
From the menu on the left, select Wireless, then Encryption.
You should be able to change the settings there.
As im sure your aware, you will have to reconfigure the other 5 clients to use WPA after doing this. I would recommend having a least on client connected by ethernet to the router so that if changes make the wireless inaccessable, you can still access the routers configuration.
Jun 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
hello!
normally, if you configure the wireless security settings wirelessly, it will automatically disconnect you from the network. you have to input the security key on the laptop first before it connects you back to the network.
i suggest, if you really like to configure the settings of your router, get an ethernet cable, connect it directly to the laptop so you can access and configure the router settings and to avoid from being disconnected
May 25, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless Router
1. you need to put the software belkin installation disc into the girls laptop not just the desktop.
2. you need to plug the modem back in
3. on the back of the router press the little button NOT THE RESET BUTTON MAKE SURE IT IS THE LOCK BUTTON it will ask you for a password on the laptop
May 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless problems
hi sir
when u r trying to connect it with urs gfs laptop
make sure u type in the correct security wep key
thank you
mike
Jan 18, 2008 | Belkin (F5D9230-4) Wireless Router...
Securing my router
Others will be able to see your router if you broadcast your SSID (basically, the name of your router). If you want that to be hidden, then there should be a setting to turn off "broadcast SSID".
If you turn off SSID broadcast, then you'll need to know it when you connect a new device to your wireless network, because it will not show up in a list of available networks.
This is considered more secure, but potentially a hassle.
Just because someone can see your router doesn't (necessarily) mean they can connect to it. If you have encryption (WEP or WPA) turned on, then they will need a passphrase to be able to connect.
In addition, you can limit access to your router to certain machines by using MAC address filtering.
Jan 14, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
268 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
