Hi, I have a blu ray DVD player in conjuction with a samsung 7.1 home theatre system.. Whenever i put on a normal DVD for at least the first 5 minutes the audio drops out consistanly..it doesn't do it much after that but occasionally throughout the film it will do it again. Is there a way to stop this from happening?
  • 1 more comment
  • varveri77 Sep 02, 2008
    ..The player is only a month old and has done this audio drop off from the beginning
  • varveri77 Sep 03, 2008
    Sorry, by normal i mean a non blu ray dvd
    Thanks very much, i didn't realise it would so serious as to be an internal hardware issue..thought it may have had something to do with configuration or set up.
    Will try for the exchange as it is most definately still under warranty.
    With Kind Regards,
    Joe
  • 4,472 Answers
Your player is still under factory warranty I would defintely replace it. It may be even soon enough to return it and exchange it for a different model where you purchased it from. Those are your best options. If you need any further assistance let me know. If you have a moment to accept and rate the solution accordingly I would greatly appreciate it. If you still need assistance please don't reject my help.
Thanks,
Lee
Posted on Sep 02, 2008
    Genius:
  • 2,028 Answers
This is going to be an internal hardware problem. Since this is only a month old, I suggest you take it back for an exchange. The store shouldn't have any problems with an exchange.
    President:
  • 1,263 Answers
By normal dvd do mean a standard formated dvd or a blu ray dvd?
  • Ronald Mueller
    Ronald Mueller Sep 03, 2008
    have you checked to see that your audio set up on your dvd player is not in conflict with your audio set up for your home theater system?
  • Ronald Mueller
    there is no reason to have to replace it i believe it's a configuration problemand it's amtter of just adjusting it accordingly
    Genius:
  • 1,847 Answers
Try cleaning the lens with a lens cleaner cd.
  • Legin Varghese
    Legin Varghese Sep 02, 2008
    Check all the cables connection from the player to the tv. after cleaning the lens try a disk which has worked fine in the past.
My Blu-ray DVD MBFH does not work on my Blu-ray player
do you have it hooked up via hdmi to a tv that has hdmi? also make sure you set the output for the dvd/blu ray player to the correct output your using (hdmi 1 or w/e not a passthru or input) also if your using component cables you may have to go to menu on the unit and select that as your outpput get back to me let me now if this helped
Mar 17, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
Nov 21, 2009 | LG BD370 BLU RAY PLAYER
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Disk stuck in my Blue Ray
Hi!
I had the same problem, and I solved it by shutting down the unit and then disconnected the power supply for some sec. When re-connecting the power supply and pushing the start button the DVD was ejected when pushed the eject button.
Egil
Dec 30, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
