Question about Kenmore 24032\24036 Top Load Washer
Brass clips do not go in
Hi jsrock,
Your instruction was excellent. I was able to follow and replace the drive couple of my kenmore 90 series. Thanks very much. However, when I was trying to reassemble everything back, I got stuck at the the last part when I need to re-install the washer case to the back/console. The brass clips were too difficult for me to push it back to the hole. Do I need special tool? How should I solve this? Thanks
  • 2 more comments
  • sisennor Sep 05, 2008
    Hi jsrock,
    as you can from the attached pic, the clip needs to be bended significantly in order to fit into the existing slots. (The alignment of case & console back is good.) I don't think brute force is gonna make it. Or else, there must be some techniques / procedures for doing so. Please advice. Thanks and appreciate that.
    -Michael
  • sisennor Sep 11, 2008
    Hi jsrock
    I don't think reversing the clip to the opposite direction will solve it. for 2 reasons:
    1) the downward loops to be pushed down into the slots of the washer case are off even more.
    2) the "J" hook currently slided into the back console (as shown in the pic) will come off rather easily if it's pushed into the front slot of the washer. It just seems an unsecured way to attached the 2 pieces together when the tub is spinning.
    I'm out of town for a few more days hence can't upload a pic to show the 1) & 2) above to you. But this is what I found. I'll upload a new pic to show you when I'm back.
    in the mean time, do you have access to other kenmore unit to confirm the orientation? how does other repair technician solve this?
    Thanks for checking with me.
    -Michael
  • sisennor Sep 16, 2008
    Hi Jsrock,
    I took a pic with the brass clip inserted in the other direction as you instructed. As you may notice from the pic, the "J" hook now can fit right into the slot, pretty much, hanging freely. With no tension joining the back and the case together, the washer will definitely shake during the spinning.
    I put the case in as you suggested. i.e. making sure the front part of the case is under the front part of the frame, and land the rest of the case on the frame.
    any suggestion?
    thanks again
    -Michael
    Hi jsrock,
    everything is put together today, and starts humming and spinning.
    Thanks very much for your help and especially your hand-holding for an amateur. Js does rock!
    -Michael
  • 5,911 Answers
No special tools are needed. You simply insert one end of the brass clip in the slot on the back panel first, then push the looped end into the hole on top of the washer case. You push straight down and the clip snaps back into place. If you are having difficulty, you may not have the back panel aligned correctly with the washer case. The panel should be flush with the washer casing on BOTH sides in order for the clips to snap back into place.
Posted on Sep 03, 2008
  • 3 more comments
  • Jeff Rockwell
    Jeff Rockwell Sep 05, 2008
    You have the clip backwards. It inserts the other way. Exchange ends and try again. The clip will go back in with no brute force or bending.
  • Jeff Rockwell
    Jeff Rockwell Sep 06, 2008
    Did you ever solve your problem? Did my explanation help you? Just following up because you never responded back after last post. Hope everything went well for you.
  • Jeff Rockwell
    Jeff Rockwell Sep 12, 2008
    I know how the clip goes back on, because I've worked on this model washer numerous times. I used to be a Sears tech. The clip you show in the above picture is definitely backwards. You have it right side up, however. The small flat "tail' (90 degree bend) at the end that you have facing the front of the washer is supposed to be insert into the slot in the back panel. Once, the tail is inserted in the slot, you push down on the "J" hook part and the clip will snap back into the two holes on top of the washer case. The only way this could be loose or misaligned is if you do not have the washer case inserted on the frame correctly. Remember: As you look down through the wash tub opening when you are placing the case back on the frame, the front lip of the washer case bottom goes UNDER the front frame support. Then, the case will lower (front-to-back) on the side supports. The side supports rest on TOP of the frame. There are small metal cleats on the frame side supports that insert into small slots on the washer case side panels. Then, you align the back panel on both sides. If you do not have the washer back together in this fashion, the clips will NOT align correctly. The back panel may be flush on both sides, but the washer case may not be aligned correctly for the clips to be inserted the way they are supposed to be. They only go back on one way. Please doublecheck your installation when you get home and let me know if you still need assistance.
    PS I do not know of any Kenmore (Sears) dealerships as I do not know where you are. This is an easy repair that you can do on your own.
  • Jeff Rockwell
    Jeff Rockwell Sep 16, 2008
    Yes...it will hang loose until you snap it back into place. Now that you have it inserted correctly, push straight down on the "J" loop until the clip snaps back into the forwardmost square slot. I've done this MANY times. You're almost there.
  • Jeff Rockwell
    Whew! Glad you're up and running now. Took us a while, but you got there. Now you're a self-made expert. Congrats.
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
I have a kenmore top loading 70 series washer that will not spin or agitate?
This is most likely due to the drive coupling. I put together some instructions on how to replace it, follow the link and let me know if it helps.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
May 09, 2010 | Kenmore Washing Machines
Replace the Lid switch on Kenmore Series 90 Washer.
Hi
Have a look at this excellent walkthrough compiled by one of our FixYa experts on how to do this procedure.
Compliments to JSRocks for this information
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
You can find further information at this link also
http://www.applianceaid.com/procedures.html#check
Thanks for using FixYa. Please do rate my answer. Thanks.
Oct 04, 2009 | Kenmore Washing Machines
Kenmore 90 series washer w broken belt
Hello I'm afraid you didnt find a belt but maybe a piece of the coupling. Here are detailed instructions on replacing a coupling: from the limited information this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
Jul 15, 2009 | Kenmore Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore gearcase
Glad to hear everything went well and you were able to use my instructions. The installation really isn't that difficult if you have some guidance. Not to mention, you just saved yourself a bunch in labor charges. Let me know if you need assistance in the future. Congrats!
Oct 18, 2008 | Kenmore 22622 Top Load Washer
How do I open the top of a Kenmore washer 80 series. Model 11092284100?
HI thanks for your question. 2 screws on each side of console. remove. lift up console. 2 brass clips , remove. disconnect lid switch connector. pull cabinet off. thanks the appliance doc. please rate my answer thanks.
Oct 09, 2008 | Kenmore Washing Machines
Kenmore washer not spinning or agitating
hi thanks for the question don't take back off please. the problem is with the motor coupling located at the motor & transmission to repair . 2 screws at console .remove .lift console .remove 2 brass clips disconnect wiring plastic disconnect pull cabinet towards you .put a block under left front lift up remove the pump 2 spring clips .remove motor wireing . remove the motor replace the motor coupling thanks the appliance doc
Sep 06, 2008 | Kenmore 20722
Kenmore 90 series agitator problem.
usually it is a gearbox drive coupling, designed to break on exceptional loads
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models
  • remove trims from ends of control panel
  • remove scres under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Jul 13, 2008 | Roper RAS8445KQ Top Load Washer
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
