Question about GE Microwave Ovens
My space saver microwave will not heat. When I turn it on it sounds like somthing is getting zapped. I cannot use it. Can you tell me what is wrong and how much it would cost to fix. Model # jvm1640cj03 serial #al900874u Year made 2006
  • GE Master
  • 9,086 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
In this model, it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
While you have the cover off, look for grease buildup or charring on the metal and the stirrer (an antenna or blade-like device).
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After checking this, please let us know if you still have trouble.
Posted on Sep 06, 2008
Runs but does not heat the food.
Microwave Not Heating Troubleshooting Guide - YouTube
? 2:45
https://www.youtube.com/watch?v=_3SbJueEn1w
Aug 31, 2012 - Uploaded by Repair.com
Allow the circuitry to dry out by avoiding stovetop cooking for a few days. .... it to microwave, but its just not warming up myfood at all, any idea on how i can .... Everything works except themicrowave- it wont heat anything up.
Microwave Diagnostic - Has Power Not Heating - GE ...
? 2:34
https://www.youtube.com/watch?v=E_iUYIV8wD0
Aug 9, 2013 - Uploaded by ApplianceVideo.com
Microwave Diagnostic - Has Power Not Heating - GE, General ....internals of a similar GE Microwave unit that would not heat food.... Sometimes it turns on, sometimes it doesn't. .... My GE microwave space saver does not heat but it comes on. ... What's Inside A Microwave Oven (Teardown / Taken Apart) ...
Nov 18, 2015 | Microwave Ovens
Jenn air microwave makes zapping sound and won't heat food
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Oct 31, 2012 | Jenn-Air Microwave Ovens
My space saver microwave will not heat anything yet everything else works.
i found on my micro setting if i accidentally set it up for convection, it stays that way and therefore just heats slowly when I think i'm microwaving. i have to re set it after i use convection or it defaults to that and therefore will not heat / microwave.
Oct 06, 2010 | GE Microwave Ovens
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave is not heating, and the table is not turning.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
76t
Oct 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE space saver Microwave not heating
heatman101
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a space saver micowave. When I start it, it sounds like somthing is getting zapped. It also does not heat. It started with microwave popcorn and does it all the time and we cannot use it. Can you...
Hi Bob,
Chances are ..you have either a bad magnetron tube or the filament transformer that is failing and arcing. The replacement cost of the parts & then labor to diagnose and install is probably more than it's worth so I would suggest you just consider buying another one. Also, Microwave Ovens radiate RF and unless you are trained in how to test for that and verify the shielding hasn't been compromised during repair, I wouldn't try to fix it myself. As an added concern, there is also High Voltage in there as well.. Your call.. but I would probably discard it and consider another one.. Hope that helps..
Oh.. for a quick test, remove everything from inside the cooking compartment and place a cup of water in there.. turn the microwave on for ~ 2 minutes..does the water get hot? boil or stay cold? If it stays cold.. discard it.. If it gets warm, the magnetron is probably in the midst of failing but if it gets hot .. then you may only have a loose connection in the electronics compartment ( magnetron, transformer etc) Something to hope for.. :-)
Sep 02, 2008 | GE Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
59 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
