Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA Looking from the back of the set right next to the flyback (the right of the flyback) are three small RED rectangle shape object. What is the flyback, do you have a diagram?
    Genius:
  • 1,030 Answers
The flyback is the big black thing on the deflection board. usally has big red wire coming out the top. THe three small rectangular items are special fusable resistor. or fuses
Posted on Sep 05, 2008
I see a possible fix for missing convergence on a rca hd52w59 by replacing the convergence fuse. I've looked all over and can't find it. If it really has this fuse, where is it??? Thanks
If your looking in the rear of the set on the far left side you will see a large black HV transformer that has a large red wire coming from its top. Thats the flyback transformer look directly to the right of that and you will see three small brown rectangles with FL221, FL231 and FL251 stamped on it. The center one is FL231 if thats blown the set will have a 3D look and the auto convergence feature will no longer be listed under the setup menu.
Dec 18, 2011 | RCA HD52W59 HDTV Projection Television
Tip
Hello Guys, Hold your horses or your remote... This is a very simple fix. There...
I ALSO HAVE A 52 INCH RCA (2 YEARS OLD) I HAVE TRIED ALL OF THE TIPS THAT HAVE BEEN DISCUSSED. LUCKILY I PURCHASED THE EXTENDED WARRANTY ON THIS UNIT.. AFTER A MONTH OF OVER THE PHONE TROUBLE SHOOTING FROM WARRANTY REPAIR CENTER THIS INCLUDED REMOVING THE BATTERIES IN CASE THE REMOTE WAS BAD. THEY FINALLY CAME AFTER IT YESTERDAY. THE PICKUP BOYS SAID THAT THEY ARE HAVING A LOT OF TROUBLE WITH THESE UNITS DOING THIS SAME THING. THEY ALSO SAID THAT SOME WERE BEING REPLACED WITH NEW ONES. NOT SURE IF RCA OR WARRANTY IS REPLACING (MINE WAS PURCHASED FROM BESTBUY WITH BEST BUY WARRANTY). IF ANYONE HAS SPOKEN TO ANYONE ABOUT A REPLACEMENT PLEASE RESPOND. I THINK IF THERE ARE SOME UNITS BEING REPLACED WITH NEW ONES WE ARE MORE THAN LIKELY GETTING THE SAME DEFECTIVE UNITS (WHICH WILL MORE THAN LIKELY WORK UNTIL OUT OF WARRANTY). I WISH THEY WOULD JUST GIVE REFUNDS OR CERTIFICATES TOWARDS NEW DIFFERENT UNITS MAYBE IF THERE WERE ENOUGH COMPLAINTS THIS MIGHT BE CONSIDERED.
on Jun 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Where is the convergence fuse located on a RCA M# R52WH76
Right to the right side of the flyback. You will see three small brown rectangle ( fuses) FL221, FL231 and FL251 the center fuse is the FL231 which is the fuse for convergence. I am posting a pic of where its located.slinteriors_14.jpg
Jul 20, 2011 | RCA R52WH76 Television
My picture tube looked bowed and in 3D. What is the problem?
change the convergence fuse located next to the flyback its red and shaped like a rectangle ref fl321 number . part number is 259213 400ma 125v you can order at ebay or from newark com for 51 cent there part number is 67K2174. its the same fuse.
Sep 11, 2010 | RCA HD52W59 HDTV Projection Television
Getting shadows and color is tinting green and yellow also there is a line across the top of screen
Locate flyback transformer. It's plastic cylindrical-shaped thing with one thin and one thick red High-Voltage wires coming from the top of it. Turn the board it soldered to around and re-solder all of it's connections applying generous amount of solder. Locate three gray-brown colored square shaped parts located right next to flyback transformer. They soldered in a row. It's fuses. Find the open one (or two) and replace them with 0.5A rated.
That should do it.
Russ.
Apr 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Issue for RCA R52WH76...
Inst_Pudding,
Please check the fuse again. Do not just pop the cap off and visually inspect it. Even if the filament appears to be intact, it's probably not. Like ctf1800 said, it's the fuse.
You need to test the fuse for continuity.
The problem that you explained is due to the blown fuse. There are no convergence IC's in this set. I'm am 99.9% certain your fuse has blown.
Get the fuse here: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=220478092023
After you install the fuse, you MUST resolder the points at the flyback transformer which is located next to the fuse (red wires leading to it). Cracked & cold solder usually develops and will cause FL231 to fail again if you skip this step.
Oct 30, 2009 | RCA R52WH76 Television
Rca d52w23 has distorted picture. it is shaped
Go to menu then setup look for convergence if not on menu you have a blowed fuse FL231 will be next to FBT flyback transfomer on right side there is 3 in a roll small brown looking caps but they are fuses it will be the one in the middle.You can take a pair of plyers to pull off top they are all removeable and just snap back on.
Sep 15, 2009 | RCA D52W23 52" HDTV CRT TV
Picture looks like its 3D what is the problem
The D52W20 had an issue with solder joints around the flyback. When you take the back off the flyback is on the very left closes to the back of the tv and has a large red wire coming out of it. Looking from the top down you will see three small orange rectangles in a row. These are fuses and one of them is going to be opened.
All you have to do is resolder the pins on the flyback and replace the fuse and you should regain convergence.
Jun 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture problems
check for cold solder joints around the flyback transformer and a open pico type fuse very close to it. they are rectangle in shape and ususually the one in the middle of the three is the culprit. The problem is in the pincushion circuit
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The tv will not power on
you have three small red rectangle shape object.these are fuses. looking from the back of the set right next to the flyback on the right.one must be open, just put another fuse in or check all three.
Aug 29, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
