RCA XS J25330BL cannot access full setup menu
1995 RCA XS J25330BL hotel/motel set,chassis number CTC177. cannot access setup and adjust menus. only programmed with hotel channels 18-74. With a master remote (which i thought i bought off of e-bay ) you are supposed to be able to access full menu but only controls (yellow) and the alarm (green) come up. the users guide says If the FM Radio feature is turned on in the middle of the initial setup, it removes the Adjust and Setup menus from the TV screen and no additional adjustments can be made to these menus. Is there any way to reset tv so i can access setup menu and reset channel list.
  • 3 more comments
  • Anonymous Sep 04, 2008
    yes i have the same problem.
  • zxuxz Sep 04, 2008
    yes i have the problem..
  • Anonymous Sep 18, 2008
    Same as Decribed above. Even bought the "master remote as well" doesn't get me into the damn correct menu
  • Anonymous Sep 20, 2008
    I have the same problem!
  • ip45371 Apr 14, 2009
    i have the same problem my tv is RCA J20300BL
    Champion:
  • 226 Answers
Your best solution is to get rid of that crappy TV! Having an old tube Tv really makes the rooms look bad.
Posted on Jul 01, 2011
I recently got a Zenith H2522DT tv from a hotel that was upgrading all of the tvs to flat screen digital units.. There was no remote control with the tv. When I got the set home, I plugged it in and...
Possible that you got a bad unit. Is there any indicator light that flashes when you turn on the tv, feel free to send feed back good day and best regards.
Aug 14, 2011 | Televison & Video
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
How do you open the menu to do an auto channel scan on a zenith H2521Y3 without a master remote. It is an old ''hotel tv'' that I ''thought'' I got a good deal on.
These hotel t.v use a particular remote so that customers can`t fool around with the setup,You may be able to get an eeprom i.c for a similar chassis from a local repair shop, but then your set may need some adjustment through the service menu i.e vertical and horizontal size, a local tv repairman may be able to help you there. good luck
Nov 12, 2009 | Zenith C27A24T 27" TV
Bought motel closeout tvs and cannot acess the menues to change the progaming how can i access the tvs main menu to make it work outside of the hotel
Each make of television has their own way of accessing the service menu to disable the hotel/motel mode.
Nov 03, 2009 | Televison & Video
I have a philips tv that i bought from a motel cant get all the channels and cant get to menu on the tv
These hotel sets have a pretty complicated setup menu. You will have to get a "master remote". The hotel has the "master remote". They really should not be selling these sets without setting them up for a non comercial application. Try www.encompassparts.com and see if they list a Master remote or a service remote. I would check myself but you didn't post a model number. You have got to have the model # for encompass.
Oct 21, 2009 | Televison & Video
I have an old RCA XS TV and cannot figure out how
Alot of the older RCA chassis required you to press 00, 91, or 92 to get to the external video input.
Oct 03, 2009 | RCA F27252GY 27" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith Concierge hotel tv wont work with my xbox 360
I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
Mar 19, 2008 | Zenith C27A24T 27" TV
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
CaseyBee
Feb 27, 2008 | Televison & Video
Televison & Video Logo
1,262 people viewed this question
Top Televison & Video Experts
