Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool Conquest I have a similar problem, the fridge compressor sounds like it starts to short cycle. Starting and running for 3 seconds and stopping for 3 seconds and if this continues it does not cool the freezer or refrigerator the refrigerator light is out, the controls are off. the freezer light is on. Now if I unplug the refrigerator, this works resets everything. It may last for several days not having the problem or 3 times a day.
  • 943 Answers
Hi thanks for the question when you say it short cycles that's the compressor relay trying to start the compressor i would replace the relay & overload at the compressor thanks the appliance doc
Posted on Sep 22, 2008
Motor egy90hlp into Whirlpool ed5fhgxkt04 start 10 sec, ang goes off 5min. come back another 10 sec. and do this cycle all day...also the compresor click on and click off sound, please helme...Alex..
From your description you have a starting problem with your compressor, this unit is called a relay. If the model number is correct, click on the relay link above and this is what your pat looks like that you need to replace.
Good Luck
Oct 12, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
1 Answer my Whirlpool gold fridge freezer is working well but has started tripping the electrics in the house each time it is switched on and the motor strarts - can you help please? Chris
its either the ptc overload on the compressor body or the start winding on the compressor itself,you will need to have a person with a clamp-probe check the starting/running currents and see how large a current this unit draws at start-up and run,then if too high a draw,its probably a bad compressor motor winding
Apr 08, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool gold conquest side by side model GS5SHAXNL00 that has a clicking noise coming from the rear. The freezer isn't keeping things frozen but the fridge side is nice and cold. I can hear the...
These models have two fans. One is located inside the unit. The fan inside blows air across the cooling coils. With the door open this fan is usually running other than defrost cycle. If this fan has stopped it will cause the compressor to overheat and the relay will cycle.
The second fan equally as important is located under a fiberboard cover accessible from the back of the unit at the bottom. This fan is usually noticeable by an air flow sound. Usually air flow is detectable out of the front grill. If this fan fails to operate, blocked due to a major build up of lint the compressor will overheat and cycle as you hear,
Hope this helps?
This is the fan inside the freezer.
Jun 25, 2017 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Unit compressor keep short cycling not feezing or
replace your compressor relay. that's what goes wrong 99% of the time
Jul 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side-by-side won't get cold, compressor clicks on-off.
Sounds like the start relay OR the compressor is no good. Have a service tech look at it, because there may be a capacitor in the circuit, which could be dangerous for you to fool with.
May 28, 2009 | Whirlpool Refrigerators
Whirlpool side by side not cooling
wihtthe modle number you can look up a part, try replacing the overload/relay( starting device) for compressor, may be bad compressor( in which ase youll need a professional) but the overload relay you can do yourself for about 60-75 bucks
Mar 28, 2009 | Refrigerators
sound like the start components are weak on the unit. you can get new start components or get a three n one control that repalces the starting components and all that you have to do is wire it up just like the diagram on the bag. or the lem could be low voltage gpoing to the refriger ator. The manufactures reccommend that you never run a refrigerator on a extenstion cord of any kind. It is also a good Idea to take the refrigerator electrical outlet off of any type of GFI receptical of any kind. you don't want to come home to a defrosted mess just because the outlet decided at that Tibme to trip.
Dec 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Problem has returned to Maytag fridge
I note this is a very old post. The compressor is not starting and what you were hearing was the PTC relay energizing followed by the KilXon thermal overload kicking off the compressor start sequence. What happens is that the PTC relays sometimes get a heated contact. Due to the weakened state of the contact it can cause a buzz. Even with a goo PTC relay you would hear the compressor buzz if it was not starting. In that case the run capacitor may have failed or the compresor rotor is internally locked at which point the start cycle will repeat every 3 to 4 minutes as the thermal overload cycles and the compressor will not start.
Thanks for choosing FixYa
Jun 18, 2008 | Refrigerators
Fridge not cold. freezer frosting up. fridge running all the time . Something sounds like it is trying to start but it will not start
If you are getting a hum for about 5-10 seconds followed by a click, tht is the compressor short cycling. You may have a bad compressor relay, or the compressor itself could be bad. If the frost your seeing is on the back wall of the fredezer that could indicate a defrost problem.
Apr 12, 2008 | Refrigerators
Whirlpool conquest side by side 2003 model
facing the back of the frige there is a cardboard or metal panel across the bottom that covers the compressor. remove panel, on left side of compressor is the main control for the frig. there is a short in that board that causes this problem. youll need to replace te board
Nov 20, 2007 | Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
248 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
