Any advice for removing a phone cable plug that's stuck inside the telepone port/jack of a Compaq Presario 900 notebook? I was able to insert the plug into the port/jack of the notebook and now I'm unable to remove it because it is snug tight in the port/jack! HELP!
  • 2,961 Answers
There should be a tiny clip that you lift with your nail on the underside of the plug
Posted on Sep 02, 2008
Compaq Presario 700, replace DC jack
go to the compute maintenance man or electronic maintainer to replace the dc jack by heating electronic
Sep 22, 2012 | Compaq Presario 700 470024-192 Notebook
How do i connect my compaq presario 1275 to the internet, using an ethernet cable? only port that i can find is a standard phone jack port
you will need something like this
Aug 05, 2011 | Compaq Presario 1275 Notebook
RJ-45 port fails to securely seat the ethernet jack
These ports are soldered onto the motherboard. They can be changed out by a tech that has the right equipment. I have been able to successfully pull these off at one time using a heat gun set to high for 15 seconds. Then the solder points need to be cleaned thoroughly and the new jack placed into the brass sleeves of the motherboard and each leg soldered into position.
Mar 26, 2010 | HP Compaq Presario R4000 Notebook
I have a Compaq Presario CQ60-215DX Notebook PC. For some reason it shuts down without warning. What can cause it to do that?
Your going to need to clean the fan/heatsink assembly..
On the cq60, this means complete disassembly of all parts and order to get to the fan properly, the motherboard will need to be removed..
Remove All screws on the underside of Laptop, Remove Covers..(hard drive,RAM,Wifi).. Pull Out CDrom....Remove the 3 screws from cdrom area.....Flip Over.. Open Screen, Pull Media Strip (above Keyboard) Away from Laptop... Be carefull Here, There are Fragile ribbon cables attached to this on the left underside ..
Now Unscrew Keyboard Screws And Pull Keyboard away, THere's a ribbon cable here too attached to the motherboard,, Unlock the ribbon cable at the motherboard port(tab on each side pulls forward).. Remove Palmrest Screws.. Pull the Wifi Cables through the Motherboard upperside, Detach any plug/wires... Unscrew Screen Hinge Posts and pull screen away... Remove the 1 screw holding the rear strip of plastic---unsnap the plastic strip at back end of palmrest area... Pull palmrest away... Unscrew The Media Card Bay and the CDrom Port Board(left side)....
Remove the 2 motherboard screws on the bottom left side front...
Unplug the long cable port on the front underside of motherboard right in the middle....
Lift up the motherboard slightly.. pulling it up from the left rear side..... You will see the DC Jack Power Cable Right There Under The Motherboard... This Needs To Be Unplugged...--Pull The Motherboard Up About 2 inches and reach under to unplug the DC Jack Wire Port Plug...and the usb plug wire...
Now continue to remove motherboard
Flip Over And Remove Heatsink Fan Assembly... Unplug Fan... Disassemble Fan And Clean FAn And Heatsink Fins...
Nov 28, 2009 | Compaq Presario Notebook
I think my compaq presario f730US notebook pc has a built in micophone but i'm not sure does it?
Compaq presario f730US notebook doesn't have an inbuilt microphone. It employs a connector (port - 3.5mm jack) to connect an external microphone.
reference : link1-cnetreview
Oct 29, 2009 | HP Compaq Presario V6000T Notebook PC
Digital audio in
just insert ur camera cable into line in jack in Audio (sky colour)
and listen it in ur PC
Feb 25, 2009 | HP Compaq Presario Media Center SR1750NX...
Compaq-presario-cq60-104tu-has audio problem
Plug in the speakers Jack,
then restart computer with headphones plugged inside.You will still hear windows startup sound.
At this point remove headphones and restart.
The problem is usually fixed in this way.
Dec 19, 2008 | Compaq Presario Notebook
I understand that now the Multimedia card is struck in the Media card reader of your notebook and you would like to know how to remove it.
Let me explain, there is no separate procedure to remove the card from the card reader.
Just insert and pull out, if it is not comming out when you pull gently, then you need technician help to remove it.
You need to contact local service center.
Aug 13, 2008 | HP Compaq Presario V2000 Notebook
If the sound is coming you have installed the driver properly
try to change the head phone jack , if doesnt help it could be the problem of your head phone socket. because when you insert the jack , circuit inside the headphone socket closes and your outside speakers will be off
Feb 08, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 900 power cord connection problem
I've fixed a couple and finally resorted to using a cable retention device like the one in this video to stop the constant tugging and jerking that seems to cause the failures. PS the design of the pins/sockets is really shabby.
Jul 27, 2007 | Compaq Presario 900US Notebook
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
