Question about Weather King 10AJA2501AH Air Conditioner
Air king problem
Unit and fan outside will start but it takes 20 mi or more for the compresor to start, is this normal
  • Seth Quisler
    Seth Quisler May 11, 2010
    the year of the model??
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
. You probably have too many time delays in your system and check the timer set points. sometime some thermostat has a time delay and the unit itself has a circuit board time delay.
Posted on Sep 04, 2008
We have a weather king central air unit mod# WAKA-030JAZ. ser#5339 mo6959417. volts 208/230. compressor rla 13 5/13.5. outdoor fan motor f.l.a.9. mfd 02/05. hertz 60. l.r.a.76. hp1/6 min supply...
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Jun 19, 2011 | Weather King Heating & Cooling
When in cooling compresor will not re start unless you are at thermorstat,move control to heat and back to cooling
moving the stat from heat to cool etc resents a fault in the control board of the inside unit or outside. Usually a high or low pressure problem
Aug 17, 2010 | Weather King 10AJA6001AH Air Conditioner
When i turn the a/c on the inside furnace motor runs but the outside compressor units does not. the compressor is a janitrol, about 20 years old
Does the outdoor fan run? If not then start by checking for tripped circuit breakers or blown fuses. If you have power then check the capacitor. If that is good then check your contactor for the fan and compressor. If that is good then check the compressor motor windings. Let me know if you have any questions.
Jun 14, 2010 | Weather King 10AJA3001AH Air Conditioner
Fan running but dont hear comp. turning on
First check for burned wires in all the componnents in the condensing unit ,also the compresor terminals ,if they're all ok and if you know how and have a tester check the compresor if is not burned or grounded. After that you can replace the capacitor (is no more than $20) and if still won't start it means the compresor is either burned or stock.You can also try to put a start booster in parallel with the capacitor ,sometimes it helps it to start.
Aug 11, 2009 | Goodman CKL60AR60 Air Conditioner
Ruud 10 compressor not working
First make sure there's power to the unit outside , if yes set the theermostat on cold ,auto and to the lowest degrees ,then look the outside unit contactor, it should be pulled in (sometimes it takes to 5 minutes beacause a time delay) , if not the problem is in the thermostat , but if yes and there's power on the other side of the contactor ,either the compresor running capacitor is bad or the compresor itself went bad .Try replacing the capacitor first (the cheaper option) and adding a startting booster in paralel with the capacitor ,if still the compresor doesn't start you nedd to replaced it.All this counting that the fan in the outside unit works ,if doesn't replaced it.
Aug 05, 2009 | Ruud Matching Split Air Conditioner
After cleaning blower on the furance outside unit will not start.
If you took the door off of the squirrel cage fan for a while the freon gets so cold the compressor cannot pump it. I will trip the outside breaker. Just let me know if during the process did wiring get moved around. Let me know, Sea Breeze
May 23, 2009 | Weather King 10AJA3001AH Air Conditioner
Weather king model 10AJA4201
Unit is over heating and setting the internal limit switch. Capacitor an/or outdoor fan could be failing.
Aug 21, 2008 | Weather King 10AJA4201AH Air Conditioner
Weather King question?
check the capacitor outside, if that doesnt work let me know.
Jun 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
43 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
