Question about Maytag Kitchen Ranges
I just went to pre heat my oven ... came back a few minutes later and it was cold, the stove top is working , Its a gas range with electronic starters... I have had no problem s with this until just now
  • 1,543 Answers
Most likely have a burnt out oven igniter. If you list your exact model number I should be able to give you a part number.
Posted on Sep 02, 2008
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
The electronic display went out on my gas range so I can not start the oven. I can still use the gas burners on the stove, but without the electrical panel I can not start the oven. I checked the wire...
This is often due to loose or corroded connections in the wiring.
Unplug the range.
Open the rear of the control panel.
Remove,then re-attach all wires on the control.
If you see any terminals corroded,clean them with a pencil eraser.
If this does not correct the problem,the clock must be replaced.
Dec 18, 2010 | Frigidaire FGFB75D Gas Kitchen Range
My gas stove model # 790.77471792 does not heat up past 100 deg. The broiler and the the top burners light. can someone tell me what the problem could be? i did notice that when I turned on the pre heat I...
The orange glow you see is coming from the oven igniter. The igniter needs to glow white hot in order to light. You need to replace the oven igniter. Hope this helps.
Nov 19, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove beeping
You have a fault in the range electrical system
Range/Stove/Oven Fault Codes Version 3 Failure
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
